Nevermind, just reinstalled. FreeNAS has been anything but easy to maintain and operate. In another case, a drive in my array failed and I still haven't been able to successfully get it to come up as Online. It shows as unavailable. Very Frustrating!!!
Yep. Thanks. Followed that 1000 times. No success. Replaced HGST (Western Digital) 3.5" Deskstar NAS drive with WD RED Nas Storage Drive. I've tried EVERYTHING I could find on Google to make it work, so far...No Freaking Luck!!!
[root@freenas ~]# zpool status
pool: Volume_01
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub repaired 0 in 3h54m with 0 errors on Tue Nov 8 03:33:40 2016
NAME STATE READ WRITE CKSUM
Volume_01 DEGRADED 0 0 0
raidz1-0 DEGRADED 0 0 0
gptid/3dadbdff-2792-11e6-bc3b-408d5c7ad1f9 ONLINE 0 0 0
13354681538441973011 UNAVAIL 0 0 0 was /dev/gptid/3e871f78-2792-11e6-bc3b-408d5c7ad
1f9
gptid/3f643ff5-2792-11e6-bc3b-408d5c7ad1f9 ONLINE 0 0 0
gptid/40491242-2792-11e6-bc3b-408d5c7ad1f9 ONLINE 0 0 0
gptid/4129798c-2792-11e6-bc3b-408d5c7ad1f9 ONLINE 0 0 0
gptid/420410b1-2792-11e6-bc3b-408d5c7ad1f9 ONLINE 0 0 0
errors: 1 data errors, use '-v' for a list
pool: freenas-boot
state: ONLINE
scan: none requested
freenas-boot ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
errors: No known data errors
[root@freenas ~]#
Did you read the error? It says you have to restore the pool from backup. This means you had a drive fail and also a read error from another drive. Whatever that data was is now gone because their is no redundancy. If you can still access your pool start backing up the important stuff soon. Then think about rebuilding.
Well, Lost it all. Just reinstalled Freenas 9.10 Stable & re-created new volumes and started over. 2 failed drives in the Raidz2 from the same lot of the same Manuf. a Real bummer! I'll be more careful to make sure I have full backups in the future.
