Update problem with pkg
Richardszu
Hi there,
I would like to update the pkg upgrade -f packages in the console or in SSH with TrueNas Core -12.0-U8.1 but I get this error message:
root@truenas[~]# pkg upgrade -f Updating local repository catalog... pkg: file:///usr/ports/packages/meta.txz: No such file or directory repository local has no meta file, using default settings pkg: file:///usr/ports/packages/packagesite.txz: No such file or directory Unable to update local repository Error updating repository!
I searched with Google and on the forum but, I did not find anything to solve this problem?
On the other hand when I do: pkg info I have a list that scrolls on the screen:
Example:
xtail-2.1
zopfli-1.0.3_1
zsh-5.8
Has anyone had this problem? And how to solve it?
Thanks for your help Richard :)
c77dk
Are you doing this directly in TrueNAS CORE CLI? Not in a jail? If so: don't
The long version: TrueNAS is an appliance, not meant to be altered, and trying to do so might break the system.
Patrick M. Hausen
The only supported way of updating any version of TrueNAS is through the UI. No user serviceable parts in that place where you are looking.
Richardszu
Thanks for your answers @c77dk @Patrick M. Hausen,
If I understand correctly, apart from updating TrueNas from the web interface, I can't modify anything directly in the CLI? But, then, how do I send with my backup script an email with a log attachment. Is it possible ?
Have a nice day Richard
Patrick M. Hausen
Configure outgoing mail and an appropriate alias for the root user in the UI. Test if mail works. Then from your script invoke something like this:
date=$(/bin/date)
(   echo "Subject: Backup Log ${date}"
    echo "From: mytruenas@mydomain.com"
    echo ""
    cat /where/ever/your/logfile/is
) | /usr/sbin/sendmail -i root
Richardszu
Thanks @Patrick M. Hausen I just tested it and it works great.
I've been looking for several weeks how to do with Bash I even wanted to install the PKG Mutt? Now I understood not to modify the systems files I ignored it and it was the updates that did the job. :mad:
I'm a beginner, that didn't escape you! I've been using TrueNas Core for about 6 months while waiting to switch to TrueNas Scale! It will be another great adventure. :wink:
A big thank you to you and for this sharing, have a great day Richard :smile:
