How to enable transmission-create on freenas transmission installation
ghostwolf59
Can someone please outline the steps to enable transmission to upload new torrents
from what I read I should be able to use the transmission-create command line to create new torrents, but the command is unknown.
Tried to install the package "pkg install transmission-cli" but that too comes back with error - no such package
root@freenas ~]# pkg upgrade
Updating local repository catalogue...
pkg: file:///usr/ports/packages/meta.txz: No such file or directory
repository local has no meta file, using default settings
pkg: file:///usr/ports/packages/packagesite.txz: No such file or directory
Unable to update repository local
All repositories are up-to-date.
Checking for upgrades (0 candidates): 100%
Processing candidates (0 candidates): 100%
Checking integrity... done (0 conflicting)
Your packages are up to date.
[root@freenas ~]# pkg install transmission-cli
pkg: No packages available to install matching 'transmission-cli' have been foun
d in the repositories
root@freenas ~]#
Don't want to install another client for this if I can avoid it so anyone that really knows how to get this feature up and running, please let me know!
cheers
D
dlavigne
Guest
Are you doing that in a jail or on the freenas system?
ghostwolf59
Tried both - both return the same error
At the moment transmission-create is missing so I recon I need to install the package - but that don't seem to work
The other reply mentioned "install missing port" - no idea what port that could be missing - transmission is up and running and works fine - Just not able to create my own torrent
Update: hmm, tried it again from within the transmission jail and the pkg install now seem to work - will see if I can use the -create torrent command once its downloaded
Update 2: Yep - Command now available
cheers
