ghostwolf59
 - Mar 2, 2013
Can someone please outline the steps to enable transmission to upload new torrents
from what I read I should be able to use the transmission-create command line to create new torrents, but the command is unknown.
Tried to install the package "pkg install transmission-cli" but that too comes back with error - no such package
Don't want to install another client for this if I can avoid it so anyone that really knows how to get this feature up and running, please let me know!
cheers
root@freenas ~]# pkg upgrade Updating local repository catalogue... pkg: file:///usr/ports/packages/meta.txz: No such file or directory repository local has no meta file, using default settings pkg: file:///usr/ports/packages/packagesite.txz: No such file or directory Unable to update repository local All repositories are up-to-date. Checking for upgrades (0 candidates): 100% Processing candidates (0 candidates): 100% Checking integrity... done (0 conflicting) Your packages are up to date. [root@freenas ~]# pkg install transmission-cli Updating local repository catalogue... pkg: file:///usr/ports/packages/meta.txz: No such file or directory repository local has no meta file, using default settings pkg: file:///usr/ports/packages/packagesite.txz: No such file or directory Unable to update repository local All repositories are up-to-date. pkg: No packages available to install matching 'transmission-cli' have been foun d in the repositories root@freenas ~]#
cheers
