Update FreeNAS-Corral-10.0.4 to FreeNAS 11 ?
m0nkey_
There is no path from Corral to 11. While based on the same OS, Corral is a completely different architecturally. If you had a previous 9.10 configuration, you can restore it in 11.
Goned
I dont have previous 9.10 configuration :(
So the solution is to reinstall to 9.10 ? and update ?
Redcoat
Oh, I see you had two posts. I made you some notes on the other (assuming you did have a previous 9.10 install configuration saved).
Goned
Yes this one is only for update another is for resolve my trouble. thanks guys
Goned
Oh ok, but for the configuration and dataset is ok ?
I have VM machines on FreeNAS Corral, is working also with 11 ?
Thanks,
No idea for my questions about VM machine on Corral if is working on 11 ?
