white_dragonn
- Jan 29, 2024
My TrueNAS system recently discovered two hard drives with a few errors on Saturday. For context, I have a pool with 4 hard drives, 1 is connected via sata and the rest is through my HBA card with sas>sata breakouts. So my immediate thought was to write down the s/n of the drives that had errors, shut down the system and check the wiring. I, as many of you probably have to, was expecting the two drives to be connected to my HBA, but no in fact one drive was on motherboard SATA and one drive was on the HBA. So this rules out a bad HBA, correct? So I booted the system back up, ran a smart long on both affected drives and they came back flawless. Ok, weird. I had also noticed the errors were erased from my dashboard, and they were not visible in Zpool status. A scrub had ran as scheduled that night too, and nothing came of it.
So now I'm confused, what just happened? Bad RAM? No, because a kernel panic would have occured? Bad PSU, likely? I mean maybe I DO in fact have a bad hba, and the sata ports on my motherboard are bad or just incompatible with linux as I've heard this is a thing from other posts. But that seems highly unlikely. I'm new to truenas, and zfs too. This is my first raid pool I've ever setup, so please take kindly with my troubleshooting steps, hopefully I missed something basic that would show my issue. Below I have listed my hardware.
Ryzen 3600
Asus Prime B550-PLUS (it is ecc compatible)
Crucial 16gb ECC UDIMM DDR4 2666MHz 2rx8 (used)
Adaptec ASR-71605 HBA Card (used, repaste + noctua fan mod, runs cold on both sides of the card.)
EVGA 600w 100-W1-0600-K1 (I know, needs to be replaced, was only supposed to be temporary but it is brand new)
APC UPC 600va/330w with truenas ups service setup.
2x 16tb Western Digital HC550
2x 18tb Western Digital HC550
Ryzen 3600
