Unsure why I got ZFS errors.
My TrueNAS system recently discovered two hard drives with a few errors on Saturday. For context, I have a pool with 4 hard drives, 1 is connected via sata and the rest is through my HBA card with sas>sata breakouts. So my immediate thought was to write down the s/n of the drives that had errors, shut down the system and check the wiring. I, as many of you probably have to, was expecting the two drives to be connected to my HBA, but no in fact one drive was on motherboard SATA and one drive was on the HBA. So this rules out a bad HBA, correct? So I booted the system back up, ran a smart long on both affected drives and they came back flawless. Ok, weird. I had also noticed the errors were erased from my dashboard, and they were not visible in Zpool status. A scrub had ran as scheduled that night too, and nothing came of it.
So now I'm confused, what just happened? Bad RAM? No, because a kernel panic would have occured? Bad PSU, likely? I mean maybe I DO in fact have a bad hba, and the sata ports on my motherboard are bad or just incompatible with linux as I've heard this is a thing from other posts. But that seems highly unlikely. I'm new to truenas, and zfs too. This is my first raid pool I've ever setup, so please take kindly with my troubleshooting steps, hopefully I missed something basic that would show my issue. Below I have listed my hardware.
Ryzen 3600
Asus Prime B550-PLUS (it is ecc compatible)
Crucial 16gb ECC UDIMM DDR4 2666MHz 2rx8 (used)
Adaptec ASR-71605 HBA Card (used, repaste + noctua fan mod, runs cold on both sides of the card.)
EVGA 600w 100-W1-0600-K1 (I know, needs to be replaced, was only supposed to be temporary but it is brand new)
APC UPC 600va/330w with truenas ups service setup.
2x 16tb Western Digital HC550
2x 18tb Western Digital HC550
Here it is.
Adaptec HBAs are poorly supported and you should be running a Broadcom/LSI HBA if you want reliability.
Here it is.
What would you recommend instead? But how did I get errors if one of the drives was connected to my motherboard's sata?
I specced out a Dell H310, would this be a more viable option for truenas? I thought those adaptec cards were fine, but I think I got the recommendation from some unraid guys....
Your system is not something we'd recommend, but if it's working and ECC is working, then it's fine. You just need to replace the HBA with an LSI IT mode HBA, such as the SAS 9300.
That said, why do you even want an HBA? For four disks, why aren't you just using the SATA ports on the motherboard?
I did have two other drives in the system, but they unfortunately had failed a few weeks back (RIP wd red, they ran for 6 years). I believe this motherboard only has 4 ports too, as I'm using an nvme for the boot media and that disables 2 satas. I'm planning on expanding this server even further soon.
My question wasn't answered though, as to why I need to replace this HBA as they aren't giving me issues and doing a google search I've seen recommendations on them. And why I was having ZFS errors if the one was using my motherboard's sata and the other drive was on the HBA.
Redcoat
I'm a Core user, not Scale (about which I know very little, but I'll try to throw some light on basic issues you may be expereincing:
First, you've not prvided near enough information for anyone here to answer your questions. For starters, the error messages you received would have likely indicated the type of errors and suggestions might then have been made to get additional pertinent information from the system to begin to drill down on the issues.
From your words you might be confused about the results of SMART testing and pool data errors - SMART results are drive only, not the data content.
There have been multiple posts here about Ryzen tweaks for stability - no overclocking for one (never on servers), then Disable Cool n Quiet and C6 states in your BIOS. These are the known stability tweaks for Ryzen boards from a quick search here.
The history of psuedo-HBA's and raid controllers has been so bad here that they'll always be fingered first as problems, and the feedback from affected users about the experience of replacing them has supported this almost-blanket recommendation.
My suggestion to you is that you do replace the HBA per @Ericloewe 's suggestion, then come back here after you are up and running again with full details about any further issues you experience.
Good luck.
EDIT - please post your long test results on your drives and the results of zpool status -v
Good luck.
Like I said the errors cleared, but this is what I got from my email service. I'm not sure how to pull up the history of errors
New alerts:
  • Pool main state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
And thank you for the info on my Ryzen motherboard, I believe I have it all set properly but I will double check as soon as I can. I will be ordering an LSI hba soon as per the recommendations, but I do want to see if this error pops up one more time to rule out if this was a weird, one time fluke. Below I have posted zpool status and long test result:
admin@truenas[~]$ sudo zpool status main
[sudo] password for admin:
pool: main
state: ONLINE
scan: scrub repaired 0B in 23:58:50 with 0 errors on Sun Jan 21 23:58:52 2024
NAME STATE READ WRITE CKSUM
main ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
282f164c-2fe7-437c-a25c-e8f9a849270c ONLINE 0 0 0
ae32555d-57c4-48aa-a4ef-ac7c47ad5d50 ONLINE 0 0 0
mirror-1 ONLINE 0 0 0
933d5cf4-524e-450d-9cc1-cf5ba6f420a2 ONLINE 0 0 0
38f95d20-65f7-476a-946f-d45f38a6d6ee ONLINE 0 0 0
errors: No known data errors
admin@truenas[~]$
/dev/sdd
# 1 Extended offline Completed without error 00% 5123 -
# 2 Extended offline Completed without error 00% 4374 -
# 3 Extended offline Interrupted (host reset) 10% 3654 -
# 4 Extended offline Completed without error 00% 2909 -
# 5 Extended offline Completed without error 00% 2192 -
# 6 Extended offline Completed without error 00% 1452 -
# 7 Extended offline Aborted by host 90% 688 -
# 8 Short offline Completed without error 00% 72 -
/dev/sda
# 1 Extended offline Completed without error 00% 1233 -
# 2 Extended offline Completed without error 00% 609 -
# 3 Short offline Completed without error 00% 81 -
Redcoat
Thanks for the follow-uip.
Well, yes, but:
1. Using zpool status main instead of zpool status -v didn't give the status of your boot pool.
2. You did not post the complete output of the smart test on the discs ( e.g. you missed the individual parameter values), and
3. You only posted for two of your 4 hard disks.
If you want help here, you'll be expected to post the complete output of diagnostic commands. I suggest that you use SSH instead of the Shell as it's easier to copy amd paste from.
I don't know where logs are in Scale so I can't help there.
Well, yes, but:
My apologies! I snipped what I thought was useful, but I will provide everything you need below. I was trying not to spam the thread. You'll see an EightTB pool that is just a drive I have plugged in for quick smb shares across the house and can be ignored. And I redacted the S/N from my smart outputs.
pool: Main
state: ONLINE
Main ONLINE 0 0 0
pool: EightTB
state: ONLINE
scan: scrub repaired 0B in 08:17:17 with 0 errors on Sun Jan 21 08:17:19 2024
EightTB ONLINE 0 0 0
fd97622d-24c3-4686-a99e-016d7e2c2941 ONLINE 0 0 0
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:01:34 with 0 errors on Wed Jan 24 03:46:35 2024
boot-pool ONLINE 0 0 0
wwn-0x5ace42e0704992fa-part3 ONLINE 0 0 0
sdf3 ONLINE 0 0 0
admin@truenas[~]$ sudo smartctl -a /dev/sdb
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.131+truenas] (local build)
Model Family: Western Digital Ultrastar DC HC550
Device Model: WDC WUH721816ALE6L4
Serial Number:
LU WWN Device Id: 5 000cca 295f2edc2
Firmware Version: PCGNW680
User Capacity: 16,000,900,661,248 bytes [16.0 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-4 published, ANSI INCITS 529-2018
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Jan 30 23:13:21 2024 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 101) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (1746) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 001 Pre-fail Always - 0
2 Throughput_Performance 0x0005 148 148 054 Pre-fail Offline - 48
3 Spin_Up_Time 0x0007 084 084 001 Pre-fail Always - 349 (Average 316)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 49
5 Reallocated_Sector_Ct 0x0033 100 100 001 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 001 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 140 140 020 Pre-fail Offline - 15
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 5777
10 Spin_Retry_Count 0x0013 100 100 001 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 49
22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 291
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 291
194 Temperature_Celsius 0x0002 066 066 000 Old_age Always - 29 (Min/Max 24/50)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 100 100 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 5096 -
# 2 Extended offline Completed without error 00% 4348 -
# 3 Extended offline Interrupted (host reset) 10% 3628 -
# 4 Extended offline Completed without error 00% 2883 -
# 5 Extended offline Completed without error 00% 2166 -
# 6 Extended offline Completed without error 00% 1426 -
# 7 Extended offline Aborted by host 90% 662 -
# 8 Extended offline Completed without error 00% 90 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
admin@truenas[~]$ sudo smartctl -a /dev/sdd
Serial Number:
LU WWN Device Id: 5 000cca 295f2ea9e
Local Time is: Tue Jan 30 23:14:11 2024 EST
been run.
command.
power-saving mode.
recommended polling time: (1697) minutes.
3 Spin_Up_Time 0x0007 084 084 001 Pre-fail Always - 331 (Average 303)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 52
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 5803
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 52
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 296
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 296
194 Temperature_Celsius 0x0002 066 066 000 Old_age Always - 29 (Min/Max 25/49)
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
admin@truenas[~]$ sudo smartctl -a /dev/sda
Device Model: WDC WUH721818ALE604
Serial Number:
LU WWN Device Id: 5 000cca 2a9d42b5a
User Capacity: 18,000,207,937,536 bytes [18.0 TB]
Local Time is: Tue Jan 30 23:15:03 2024 EST
been run.
command.
power-saving mode.
recommended polling time: (1977) minutes.
2 Throughput_Performance 0x0005 147 147 054 Pre-fail Offline - 52
3 Spin_Up_Time 0x0007 094 094 001 Pre-fail Always - 270
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 1292
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 58
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 58
194 Temperature_Celsius 0x0002 066 066 000 Old_age Always - 29 (Min/Max 25/34)
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
admin@truenas[~]$ sudo smartctl -a /dev/sde
Serial Number:
LU WWN Device Id: 5 000cca 2a9c93664
Local Time is: Tue Jan 30 23:15:32 2024 EST
been run.
command.
power-saving mode.
recommended polling time: (2022) minutes.
2 Throughput_Performance 0x0005 149 149 054 Pre-fail Offline - 44
3 Spin_Up_Time 0x0007 093 093 001 Pre-fail Always - 283
194 Temperature_Celsius 0x0002 065 065 000 Old_age Always - 30 (Min/Max 25/34)
No Errors Logged
# 1 Extended offline Completed without error 00% 1236 -
# 2 Extended offline Completed without error 00% 607 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Redcoat
Thanks for the follow up.
Nothing here looks awry to me.
Let's see what happens with a real HBA...
