A year ago, this forum help me pick the HW for my budget build. My goal was to get to know Truenas. A year later, I am a Truenas fan. Actually Truenas Scale fan. Thank you. If I may, I would like your advice for upgrading my system.
I have 2 Truenas systems (Dell PowerEdge T320 Tower E5-2440, each with a For LSI 6Gbps SAS HBA 9240-8I IT Mode ZFS FreeNAS unRAID + 2*SFF-8087 SATA and each of these Truenas and my server has a 10Gb SFP+ PCI-E Network Card NIC, with Broadcom BCM57810S Chip, Dual SFP+ Port, PCI Express X8, Support Windows Server /Linux/VMware) card. The disks are qty 6 of 4TB in each of the Truenas systems. The disks were the cheapest no-name brands I could find on eBay arranged in a Z2 configuration.
My server -> truenas1 -> truenas2
-> backblaze
I am now getting rather attached to my data, so am getting a little scared with the no-name brand disks. Also, the Z2 pools are 80% full.
So I purchased qty 6 Western Digital 16TB WD Red Pro NAS Internal Hard Drive HDD - 7200 RPM, SATA 6 Gb/s, CMR, 256 MB Cache, 3.5" - WD161KFGX. I am in the process of replacing the disk in Truenas1. I would like to use the non-name disk removed from Truenas1 and place them in Truenas2. This way I get 4x capacity in Truenas1, and 2x capacity in truenas2.
Can someone recommend a low-budget 12 or 16 bay server on ebay that I could use to replace Truenas2?
It will sit in my office, so it can't be a screamer.
Cannibalizing Truenas2 is an option if it helps.
-> backblaze
