unknown serial in gui
boecko
i've installed FreeNAS as a VMWare-ESX-Guest.
Two NEW SATA-Disks (each 1TB) are attached as RAW-Devices (createType="vmfsPassthroughRawDeviceMap") and build a ZFS-Mirror-Volume
It seems to me that GUI is out of sync with the actual ZFS-Pool.
# zpool status -v
  pool: vg1
 state: ONLINE
 scrub: scrub completed after 5h14m with 0 errors on Tue Oct 11 04:54:04 2011
	vg1         ONLINE       0     0     0
	  mirror    ONLINE       0     0     0
	    da1p2   ONLINE       0     0     0
	    da2p2   ONLINE       0     0     0
errors: No known data errors
In the GUI, the da2-disk is missing.
How can i correct this issue?
I cant't find any serial in /data/freenas-v1.db, so where does this info come from?
da2 is show as replacement alternative, but maybe it's just a UUID-missmatch.
Thanks
boecko
92MB/s
Hi boecko,
there's the same with me. Not only the serial is missing, also the drive has no name (ada0, ada1,...)
I'm not shure, if this is serious, or just a cosmetic error.
It happend to my FreeNAS, after I detached 1 of the 5 harddrives, to see if RAID-Z does recovering, after drive replacement. So I got this one drive, deleted the partitions and connected it again. After FreeNAS came up, and me klicking on <Replace> in View All Volumes-->View Disks, and several screen updates bei pressing <F5>, the alert LED changed from flashig-red, to steady-green again, and my zpool was healthy again. So I was happy,... at first.
But this test was with allmost no data on the drives.
In the second test, I copied 500 GB Data into the zpool, formated the same drive I took before with fat32 and powerd up FreeNAS again.
Then things changed, compared to the test before. First clicking <Replace>, and screen update with <F5> over 2 hours didn't help and seemed to do nothing. Still the red-flashing LED...
Then I rebooted the system and everthing was announced as healthy. So I was happy at first. But then I saw the missing drive name and the other things mentioned before.
So, if you discover anything (or somebody else here), please let me know.
I don't really care about drive-names and things, as long everthing works the right way.
Anybody out there who knows more about this?
Greets,
92MB/s
boecko
small update, it has to do with the output of
sysctl -b kern.geom.confxml
The "unknown" is a subsequent fault, because the webgui doesn't know the name.
  • gui searches for the uuid in the xml to get the name
  • invokes smartctl -i /dev/<name> to get the serial
My first uuid is found in the XML. The second not.=> go figure.
boecko
So the solution is
  • dump xml
    $ cd /data
    $ sysctl -b kern.geom.confxml  > geom.xml
  • search for the missing device in the <provider>-tags
    In my case it was ad2p2 - you should check the XML for your working UUID
  • copy the rawuuid
  • replace the uuid in the freenas-v1.db
    $ cd /data
    $ sqlite3 freenas-v1.db
    sqlite> SELECT disk_identifier FROM storage_disk WHERE disk_name='da2';
    {uuid}572f5347-f2c8-11e0-a5ca-000c29617b1c
    UPDATE storage_disk SET disk_identifier = '{uuid}<rawuuid>' WHERE disk_name='<YOURDISK>';
I'm guessing this happens when the geometry has changed for the kernel. Why ?
