Unhealthy Pool
rlillard
Hello and new to Truenas so I am a rookie. Just setup Truenas and installed 2 red WD 6Gb drives and created a striped pool. I am using it to store media files for Plex. On one of the 6Gb drives I am getting Checksum errors. What are some of the things I should try? Could it be I have a bad drive or should I try and move it to a new sata port? If I move it will it destroy my pool?
Warning: settings changed through the CLI are not written to the configuration database and will be reset on reboot. root@truenas[~]# zpool status -xv pool: media state: ONLINE status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A scan: scrub repaired 0B in 00:58:34 with 11 errors on Tue Apr 5 21:52:52 2022 config: NAME STATE READ WRITE CKSUM media ONLINE 0 0 0 gptid/5fa0a006-b45b-11ec-8827-7824af3aa446 ONLINE 0 0 3 gptid/5faa3f91-b45b-11ec-8827-7824af3aa446 ONLINE 0 0 10 errors: Permanent errors have been detected in the following files: /mnt/media/media/Kids/Despicable Me 2.avi media/media:<0x2b> /mnt/media/media/Movies/Star Wars/The Mandalorian/Star Wars - The Mandalorian Movie - Part I (2019).mkv /mnt/media/media/Kids/How to Train Your Dragon - The Hidden World 2019.mkv /mnt/media/media/Kids/onward.2020.catalan.multi.1080p.bluray.x264-despacito.mkv media/media:<0x86> /mnt/media/media/Kids/Goosebumps 2015.mkv /mnt/media/media/Movies/Star Wars/The Mandalorian/Star Wars - The Mandalorian Movie - Part II (2019).mkv /mnt/media/media/Movies/Free.Guy.2021.1080p.HDRip.X264.DD5.1-EVO.mkv
Use smartctl -h to get a usage summary root@truenas[~]# smartctl -a /dev/ada3 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p12 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red (SMR) Device Model: WDC WD60EFAX-68JH4N1 Serial Number: WD-WX72DA12ZL4E LU WWN Device Id: 5 0014ee 2bf5de6cd Firmware Version: 83.00A83 User Capacity: 6,001,175,126,016 bytes [6.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches TRIM Command: Available, deterministic, zeroed Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Tue Apr 5 22:07:07 2022 CDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (29280) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 67) minutes. Conveyance self-test routine recommended polling time: ( 1) minutes. SCT capabilities: (0x3039) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 100 253 021 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 1 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 32 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 1 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 0 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 2 194 Temperature_Celsius 0x0022 119 115 000 Old_age Always - 31 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing
NugentS
CHKSUM errors are usually (but not always) the result of a bad cable. Reseat (preferably replace) the SATA cable.
You do realise that with a stripe you have no resiliancy and no way of fixing bit rot / bad files. Lose one drive and you lose the whole pool.
You need to send these back and get CMR drives.
SMR drives are no good for ZFS and should not be used with TrueNAS.
rlillard
Thank you!
rlillard
Yes I realize that about the redundancy but I really don't need it. This pool will only be for video files for Plex. If I lose them I could replace the files. I would rather have the space than the redundancy.
jgreco
Resident Grinch
You may have misunderstood what @NugentS said. If you lose a drive, you lose the *pool*, not just some files. Replacing terabytes of files is a terra-fying prospect in most cases.
rlillard
Yeah after thinking about this I am sending the 2 x 6TB SMR's back and getting 2 x 8TB CMR's and will run them mirror. Thanks for all the suggestions. Like I said I am new to Truenas but I have to say this is a powerful platform and I am liking what I am seeing.
