Hi ,
I am trying to update my freenas system from 11.2-u7 to 11.3 using system>update
from GUI . After updating and reboot it stuck to
| " middlewared: setting up plugins (pwenc) [2/45] error and then waiting to 10 minutes it shows error of "failed to run middleware call Daemon not running error" as given below and then login prompt where i can login with admin/root and able to ping all local IPs and google.com but still i am unable to access freenas GUI through the existing freenas IP address and shows error of "connecting to freenas .Make sure your freenas system is powered on and connected to internet " on web brower . One more thing running dmesg -a command line in local freenas terminal shows "error resolving pool 0.freebsd.pool.ntp.org:hostname or server name not provided or not known " Is this can be the reason of GUI not showing or any other reason . I have checked same error in multiple queries in forums and took action like changing pen drive, fresh install of 11.3 OS on new pen drive and then restore config file but same issue in all cases .If fresh install 11.3 or truenas12 in pen drive and then restore backup from truenas gui screen then again stuck to same errors after reboot . Pls suggest for possible solutions .Thanks in advance .
