socra
- Nov 3, 2018
Currently running 11.2-u1 native on a otherwise stable system.
I was writing some data to a cifs share when all of a sudden the copy action was broken off.
FreeNAS showed an alert about an error occurred and data corruption may have happend:
Rebooted the box since and box booted fine except the encrypted drive is now not available.
The pool is shown as locked:
The drive is now shown as unused:
glabel status
Logging showed this during the copy:
smartctl output of the drive. (currently running a long test):
tried to attach the drive after the reboot:
So I think 2 questions come to mind:
1) Anyone an idea why this happend? (drive seems oke?)
2) Is there a way to remount the encrypted drive ?
Thanks for reading and your time!
- Freenas 11.2-U1
- 8GB non-ECC
Intel(R) Core(TM) i3-4160 CPU @ 3.60GHz (4 cores)
MSI Motherboard
SSD for bootdrive
Couple of data drives for my media collection (which are connected to an LSI HBA card)
Drive in question is connected directly to the motherboard and not to the LSI card.
glabel status
Name Status Components gptid/ea5c5c32-fcae-11e8-8985-448a5bca6d50 N/A ada0p1 gptid/9de944b6-1676-11e9-b2dd-448a5bca6d50 N/A ada1p2 gptid/bce3642e-fcb4-11e8-abaf-448a5bca6d50 N/A da0p2 gptid/364b08d6-fde6-11e8-abaf-448a5bca6d50 N/A da1p2 gptid/c595e422-ff7f-11e8-8cfa-448a5bca6d50 N/A da2p2
Mar 16 12:03:55 yoda ahcich2: Timeout on slot 8 port 0 Mar 16 12:03:55 yoda ahcich2: is 00000000 cs fffffe07 ss ffffff07 rs ffffff07 tfd 40 serr 00000000 cmd 0000c817 Mar 16 12:03:55 yoda (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 68 a4 ae 40 5f 00 00 00 00 00 Mar 16 12:03:55 yoda (ada1:ahcich2:0:0:0): CAM status: Command timeout Mar 16 12:03:55 yoda (ada1:ahcich2:0:0:0): Retrying command Mar 16 12:04:25 yoda ahcich2: Timeout on slot 5 port 0 Mar 16 12:04:25 yoda ahcich2: is 00000000 cs f8000000 ss ffffffe0 rs ffffffe0 tfd c0 serr 00000000 cmd 0000db17 Mar 16 12:04:25 yoda (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 18 78 3c 41 40 52 00 00 00 00 00 Mar 16 12:04:25 yoda (ada1:ahcich2:0:0:0): CAM status: Command timeout Mar 16 12:04:25 yoda (ada1:ahcich2:0:0:0): Retrying command Mar 16 12:04:55 yoda ahcich2: Timeout on slot 2 port 0 Mar 16 12:04:55 yoda ahcich2: is 00000000 cs 1fffffc0 ss 1ffffffc rs 1ffffffc tfd c0 serr 00000000 cmd 0000c617 Mar 16 12:04:55 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 58 fe 73 40 3e 00 00 01 00 00 Mar 16 12:04:55 yoda (ada1:ahcich2:0:0:0): CAM status: Command timeout Mar 16 12:04:55 yoda (ada1:ahcich2:0:0:0): Retrying command Mar 16 12:06:33 yoda ahcich2: Timeout on slot 2 port 0 Mar 16 12:06:33 yoda ahcich2: is 00000000 cs 00000004 ss 00000000 rs 00000004 tfd c0 serr 00000000 cmd 0000c217 Mar 16 12:06:33 yoda (ada1:ahcich2:0:0:0): WRITE_DMA48. ACB: 35 00 78 d0 69 40 60 00 00 00 00 01 Mar 16 12:06:33 yoda (ada1:ahcich2:0:0:0): CAM status: Command timeout Mar 16 12:06:33 yoda (ada1:ahcich2:0:0:0): Retrying command Mar 16 12:07:04 yoda ahcich2: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 16 12:07:34 yoda ahcich2: Timeout on slot 3 port 0 Mar 16 12:07:34 yoda ahcich2: is 00000000 cs 00000008 ss 00000000 rs 00000008 tfd 80 serr 00000000 cmd 0000c317 Mar 16 12:07:34 yoda (aprobe0:ahcich2:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 Mar 16 12:07:34 yoda (aprobe0:ahcich2:0:0:0): CAM status: Command timeout Mar 16 12:07:34 yoda (aprobe0:ahcich2:0:0:0): Retrying command Mar 16 12:08:06 yoda ahcich2: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 16 12:08:35 yoda ahcich2: Timeout on slot 4 port 0 Mar 16 12:08:35 yoda ahcich2: is 00000000 cs 00000010 ss 00000000 rs 00000010 tfd 80 serr 00000000 cmd 0000c417 Mar 16 12:08:35 yoda (aprobe0:ahcich2:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 Mar 16 12:08:35 yoda (aprobe0:ahcich2:0:0:0): CAM status: Command timeout Mar 16 12:08:35 yoda (aprobe0:ahcich2:0:0:0): Error 5, Retries exhausted Mar 16 12:09:07 yoda ahcich2: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 16 12:09:37 yoda ahcich2: Timeout on slot 5 port 0 Mar 16 12:09:37 yoda ahcich2: is 00000000 cs 00000020 ss 00000000 rs 00000020 tfd 80 serr 00000000 cmd 0000c517 Mar 16 12:09:37 yoda (aprobe0:ahcich2:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 Mar 16 12:09:37 yoda (aprobe0:ahcich2:0:0:0): CAM status: Command timeout Mar 16 12:09:37 yoda (aprobe0:ahcich2:0:0:0): Error 5, Retry was blocked Mar 16 12:09:37 yoda ada1 at ahcich2 bus 0 scbus2 target 0 lun 0 Mar 16 12:09:37 yoda ada1: <SAMSUNG HD103UJ 1AA01118> s/n S13PJX0C400547 detached Mar 16 12:09:37 yoda GEOM_ELI: g_eli_read_done() failed (error=6) gptid/9de944b6-1676-11e9-b2dd-448a5bca6d50.eli[READ(offset=801730490368, length=4096)] Mar 16 12:09:37 yoda GEOM_ELI: g_eli_read_done() failed (error=6) gptid/9de944b6-1676-11e9-b2dd-448a5bca6d50.eli[READ(offset=270336, length=8192)] Mar 16 12:09:37 yoda GEOM_ELI: g_eli_read_done() failed (error=6) gptid/9de944b6-1676-11e9-b2dd-448a5bca6d50.eli[READ(offset=998056665088, length=8192)] Mar 16 12:09:37 yoda GEOM_ELI: g_eli_read_done() failed (error=6) gptid/9de944b6-1676-11e9-b2dd-448a5bca6d50.eli[READ(offset=998056927232, length=8192)] Mar 16 12:10:08 yoda ahcich2: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 16 12:10:39 yoda ahcich2: Timeout on slot 6 port 0 Mar 16 12:10:39 yoda ahcich2: is 00000000 cs 00000040 ss 00000000 rs 00000040 tfd 80 serr 00000000 cmd 0000c617 Mar 16 12:10:39 yoda (aprobe0:ahcich2:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 Mar 16 12:10:39 yoda (aprobe0:ahcich2:0:0:0): CAM status: Command timeout Mar 16 12:10:39 yoda (aprobe0:ahcich2:0:0:0): Retrying command Mar 16 12:11:10 yoda ahcich2: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 16 12:11:40 yoda ahcich2: Timeout on slot 7 port 0 Mar 16 12:11:40 yoda ahcich2: is 00000000 cs 00000080 ss 00000000 rs 00000080 tfd 80 serr 00000000 cmd 0000c717 Mar 16 12:11:40 yoda (aprobe0:ahcich2:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 Mar 16 12:11:40 yoda (aprobe0:ahcich2:0:0:0): CAM status: Command timeout Mar 16 12:11:40 yoda (aprobe0:ahcich2:0:0:0): Error 5, Retries exhausted Mar 16 12:12:26 yoda ahcich2: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 16 12:12:26 yoda ahcich2: Poll timeout on slot 9 port 0 Mar 16 12:12:26 yoda ahcich2: is 00000000 cs 00000200 ss 00000000 rs 00000200 tfd 80 serr 00000000 cmd 0000c917 Mar 16 12:12:26 yoda (aprobe0:ahcich2:0:0:0): NOP FLUSHQUEUE. ACB: 00 00 00 00 00 00 00 00 00 00 00 00 Mar 16 12:12:26 yoda (aprobe0:ahcich2:0:0:0): CAM status: Command timeout Mar 16 12:12:26 yoda (aprobe0:ahcich2:0:0:0): Error 5, Retries exhausted Mar 16 12:13:27 yoda ahcich2: Timeout on slot 10 port 0 Mar 16 12:13:27 yoda ahcich2: is 00000000 cs 00000400 ss 00000000 rs 00000400 tfd 80 serr 00000000 cmd 0000ca17 Mar 16 12:13:27 yoda (ada1:ahcich2:0:0:0): WRITE_DMA48. ACB: 35 00 78 d0 69 40 60 00 00 00 00 01 Mar 16 12:13:27 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:13:27 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:14:13 yoda ahcich2: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 16 12:14:13 yoda xptioctl: pass driver is not in the kernel Mar 16 12:14:13 yoda xptioctl: put "device pass" in your kernel config file Mar 16 12:14:13 yoda ahcich2: Poll timeout on slot 12 port 0 Mar 16 12:14:13 yoda ahcich2: is 00000000 cs 00001000 ss 00000000 rs 00001000 tfd 80 serr 00000000 cmd 0000cc17 Mar 16 12:14:13 yoda (aprobe0:ahcich2:0:0:0): NOP FLUSHQUEUE. ACB: 00 00 00 00 00 00 00 00 00 00 00 00 Mar 16 12:14:13 yoda (aprobe0:ahcich2:0:0:0): CAM status: Command timeout Mar 16 12:14:13 yoda (aprobe0:ahcich2:0:0:0): Error 5, Retries exhausted Mar 16 12:14:43 yoda ahcich2: Timeout on slot 13 port 0 Mar 16 12:14:43 yoda ahcich2: is 00000000 cs 00002000 ss 00000000 rs 00002000 tfd 80 serr 00000000 cmd 0000cd17 Mar 16 12:14:43 yoda (ada1:ahcich2:0:0:0): SETFEATURES ENABLE RCACHE. ACB: ef aa 00 00 00 40 00 00 00 00 00 00 Mar 16 12:14:43 yoda (ada1:ahcich2:0:0:0): CAM status: Command timeout Mar 16 12:14:43 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:15:29 yoda ahcich2: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 16 12:15:29 yoda ahcich2: Poll timeout on slot 15 port 0 Mar 16 12:15:29 yoda ahcich2: is 00000000 cs 00008000 ss 00000000 rs 00008000 tfd 80 serr 00000000 cmd 0000cf17 Mar 16 12:15:29 yoda (aprobe0:ahcich2:0:0:0): NOP FLUSHQUEUE. ACB: 00 00 00 00 00 00 00 00 00 00 00 00 Mar 16 12:15:29 yoda (aprobe0:ahcich2:0:0:0): CAM status: Command timeout Mar 16 12:15:29 yoda (aprobe0:ahcich2:0:0:0): Error 5, Retries exhausted Mar 16 12:15:59 yoda ahcich2: Timeout on slot 16 port 0 Mar 16 12:15:59 yoda ahcich2: is 00000000 cs 00010000 ss 00000000 rs 00010000 tfd 80 serr 00000000 cmd 0000d017 Mar 16 12:15:59 yoda (ada1:ahcich2:0:0:0): SETFEATURES ENABLE WCACHE. ACB: ef 02 00 00 00 40 00 00 00 00 00 00 Mar 16 12:15:59 yoda (ada1:ahcich2:0:0:0): CAM status: Command timeout Mar 16 12:15:59 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:16:46 yoda ahcich2: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 16 12:16:46 yoda ahcich2: Poll timeout on slot 18 port 0 Mar 16 12:16:46 yoda ahcich2: is 00000000 cs 00040000 ss 00000000 rs 00040000 tfd 80 serr 00000000 cmd 0000d217 Mar 16 12:16:46 yoda (aprobe0:ahcich2:0:0:0): NOP FLUSHQUEUE. ACB: 00 00 00 00 00 00 00 00 00 00 00 00 Mar 16 12:16:46 yoda (aprobe0:ahcich2:0:0:0): CAM status: Command timeout Mar 16 12:16:46 yoda (aprobe0:ahcich2:0:0:0): Error 5, Retries exhausted Mar 16 12:17:16 yoda ahcich2: Timeout on slot 19 port 0 Mar 16 12:17:16 yoda ahcich2: is 00000000 cs fffbffff ss fffbffff rs fffbffff tfd 80 serr 00000000 cmd 0000d317 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 78 d1 69 40 60 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Command timeout Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 c3 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 c4 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda GEOM_ELI: (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 c5 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda g_eli_write_done() failed (error=5)(ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 c6 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda gptid/9de944b6-1676-11e9-b2dd-448a5bca6d50.eli[WRITE(offset=826035924992, length=1048576)](ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 c7 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 c8 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 c9 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 ca 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 cb 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 cc 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 cd 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 ce 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 cf 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 d0 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 d1 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 d2 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 d3 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 d4 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 78 d2 69 40 60 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 78 d3 69 40 60 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 78 d4 69 40 60 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 78 d5 69 40 60 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 78 d6 69 40 60 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 78 d7 69 40 60 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 78 d8 69 40 60 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 78 d9 69 40 60 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 bf 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 c0 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 c1 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 10 c2 60 40 55 00 00 01 00 00 Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): CAM status: Unconditionally Re-queue Request Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Error 5, Periph was invalidated Mar 16 12:17:16 yoda GEOM_ELI: g_eli_read_done() failed (error=5) gptid/9de944b6-1676-11e9-b2dd-448a5bca6d50.eli[READ(offset=731244208128, length=1048576)] Mar 16 12:17:16 yoda GEOM_ELI: g_eli_read_done() failed (error=6) gptid/9de944b6-1676-11e9-b2dd-448a5bca6d50.eli[READ(offset=731245256704, length=1048576)] Mar 16 12:17:16 yoda GEOM_ELI: g_eli_write_done() failed (error=5) gptid/9de944b6-1676-11e9-b2dd-448a5bca6d50.eli[WRITE(offset=826036973568, length=1048576)] Mar 16 12:17:16 yoda GEOM_ELI: g_eli_read_done() failed (error=5) gptid/9de944b6-1676-11e9-b2dd-448a5bca6d50.eli[READ(offset=731243159552, length=1048576)] Mar 16 12:17:16 yoda ZFS: vdev state changed, pool_guid=3940863797859595156 vdev_guid=16342206147851125131 Mar 16 12:17:16 yoda GEOM_MIRROR: Device swap1: provider ada1p1 disconnected. Mar 16 12:17:16 yoda GEOM_ELI: Device gptid/9de944b6-1676-11e9-b2dd-448a5bca6d50.eli destroyed. Mar 16 12:17:16 yoda GEOM_ELI: Detached gptid/9de944b6-1676-11e9-b2dd-448a5bca6d50.eli on last close. Mar 16 12:17:16 yoda (ada1:ahcich2:0:0:0): Periph destroyed Mar 16 12:17:18 yoda GEOM_ELI: Device mirror/swap1.eli destroyed. Mar 16 12:17:20 yoda GEOM_MIRROR: Device swap1: provider destroyed. Mar 16 12:17:20 yoda GEOM_MIRROR: Device swap1 destroyed. Mar 16 12:17:21 yoda savecore: /dev/da0p1: Operation not permitted Mar 16 12:18:03 yoda ahcich2: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 16 12:18:03 yoda ahcich2: Poll timeout on slot 19 port 0 Mar 16 12:18:03 yoda ahcich2: is 00000000 cs 00080000 ss 00000000 rs 00080000 tfd 80 serr 00000000 cmd 0000d317 Mar 16 12:18:03 yoda (aprobe0:ahcich2:0:0:0): NOP FLUSHQUEUE. ACB: 00 00 00 00 00 00 00 00 00 00 00 00 Mar 16 12:18:03 yoda (aprobe0:ahcich2:0:0:0): CAM status: Command timeout Mar 16 12:18:03 yoda (aprobe0:ahcich2:0:0:0): Error 5, Retries exhausted
smartctl output of the drive. (currently running a long test): smartctl -a /dev/ada1 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: SAMSUNG SpinPoint F1 DT Device Model: SAMSUNG HD103UJ Serial Number: LU WWN Device Id: 5 0000f0 00b045074 Firmware Version: 1AA01118 User Capacity: 1,000,204,886,016 bytes [1.00 TB] Sector Size: 512 bytes logical/physical Device is: In smartctl database [for details use: -P show] ATA Version is: ATA/ATAPI-7, ATA8-ACS T13/1699-D revision 3b Local Time is: Sat Mar 16 13:40:35 2019 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 247) Self-test routine in progress... 70% of test remaining. Total time to complete Offline data collection: (12482) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 209) minutes. Conveyance self-test routine recommended polling time: ( 22) minutes. SCT capabilities: (0x003f) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 100 100 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0007 078 078 011 Pre-fail Always - 7330 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 140 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 253 253 051 Pre-fail Always - 0 8 Seek_Time_Performance 0x0025 100 100 015 Pre-fail Offline - 11792 9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 4499 10 Spin_Retry_Count 0x0033 100 100 051 Pre-fail Always - 0 11 Calibration_Retry_Count 0x0012 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 136 13 Read_Soft_Error_Rate 0x000e 100 100 000 Old_age Always - 0 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 184 End-to-End_Error 0x0033 100 100 000 Pre-fail Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 076 059 000 Old_age Always - 24 (Min/Max 24/24) 194 Temperature_Celsius 0x0022 073 056 000 Old_age Always - 27 (Min/Max 24/27) 195 Hardware_ECC_Recovered 0x001a 100 100 000 Old_age Always - 955 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 100 100 000 Old_age Always - 1 200 Multi_Zone_Error_Rate 0x000a 100 100 000 Old_age Always - 0 201 Soft_Read_Error_Rate 0x000a 100 100 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Self-test routine in progress 70% 4499 - # 2 Short offline Completed without error 00% 4480 - # 3 Short offline Completed without error 00% 4432 - # 4 Short offline Completed without error 00% 4407 - # 5 Short offline Completed without error 00% 4388 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
geli attach -k /mnt//temp/yoda-pool80-geli.key /dev/ada1 geli: Cannot read metadata from /dev/ada1: Invalid argument.
