WRITE_FPDMA_QUEUED errors
smartyarts
Hey guys, I have finally set it up to RAIDZ2 and yes, it resulted in about 6.8TB of space. I started to backup stuff from a mac to a driveset and after approximately 1 TB of data that has been copied to the FreeNAS fileserver I receive these errors:
Feb  4 00:00:00 freenas newsyslog[31787]: logfile turned over due to size>200K
Feb  4 00:00:00 freenas syslog-ng[1875]: Configuration reload request received, reloading configuration;
Feb  4 00:00:45 freenas daemon[3136]:	 2018/02/04 00:00:45 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:02:45 freenas daemon[3136]:	 2018/02/04 00:02:45 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:04:46 freenas daemon[3136]:	 2018/02/04 00:04:46 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:06:46 freenas daemon[3136]:	 2018/02/04 00:06:46 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:08:46 freenas daemon[3136]:	 2018/02/04 00:08:46 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:10:46 freenas daemon[3136]:	 2018/02/04 00:10:46 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:12:47 freenas daemon[3136]:	 2018/02/04 00:12:47 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:14:47 freenas daemon[3136]:	 2018/02/04 00:14:47 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:16:47 freenas daemon[3136]:	 2018/02/04 00:16:47 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:18:48 freenas daemon[3136]:	 2018/02/04 00:18:48 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:20:48 freenas daemon[3136]:	 2018/02/04 00:20:48 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:22:48 freenas daemon[3136]:	 2018/02/04 00:22:48 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:24:48 freenas daemon[3136]:	 2018/02/04 00:24:48 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:26:34 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 98 f8 b3 c2 40 45 01 00 00 00 00
Feb  4 00:26:34 freenas (ada2:ahcich2:0:0:0): CAM status: Uncorrectable parity/CRC error
Feb  4 00:26:34 freenas (ada2:ahcich2:0:0:0): Retrying command
Feb  4 00:26:34 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 80 d0 69 c2 40 45 01 00 00 00 00
Feb  4 00:26:49 freenas daemon[3136]:	 2018/02/04 00:26:49 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:28:49 freenas daemon[3136]:	 2018/02/04 00:28:49 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:30:06 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 00 a6 3b 40 46 01 00 01 00 00
Feb  4 00:30:06 freenas (ada2:ahcich2:0:0:0): CAM status: Uncorrectable parity/CRC error
Feb  4 00:30:06 freenas (ada2:ahcich2:0:0:0): Retrying command
Feb  4 00:30:06 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 00 a7 3b 40 46 01 00 01 00 00
Feb  4 00:30:06 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 00 a8 3b 40 46 01 00 01 00 00
Feb  4 00:30:06 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 90 00 a9 3b 40 46 01 00 00 00 00
Feb  4 00:30:08 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 d8 58 d2 3c 40 46 01 00 00 00 00
Feb  4 00:30:08 freenas (ada2:ahcich2:0:0:0): CAM status: Uncorrectable parity/CRC error
Feb  4 00:30:08 freenas (ada2:ahcich2:0:0:0): Retrying command
Feb  4 00:30:09 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 90 76 3d 40 46 01 00 01 00 00
Feb  4 00:30:09 freenas (ada2:ahcich2:0:0:0): CAM status: Uncorrectable parity/CRC error
Feb  4 00:30:09 freenas (ada2:ahcich2:0:0:0): Retrying command
Feb  4 00:30:09 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 90 77 3d 40 46 01 00 01 00 00
Feb  4 00:30:09 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 90 78 3d 40 46 01 00 01 00 00
Feb  4 00:30:09 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 90 79 3d 40 46 01 00 01 00 00
Feb  4 00:30:09 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 90 7a 3d 40 46 01 00 01 00 00
Feb  4 00:30:09 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 90 7b 3d 40 46 01 00 01 00 00
Feb  4 00:30:09 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 c0 90 7c 3d 40 46 01 00 00 00 00
Feb  4 00:30:25 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 38 64 48 40 a0 01 00 01 00 00
Feb  4 00:30:25 freenas (ada2:ahcich2:0:0:0): CAM status: Uncorrectable parity/CRC error
Feb  4 00:30:25 freenas (ada2:ahcich2:0:0:0): Retrying command
Feb  4 00:30:25 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 38 65 48 40 a0 01 00 01 00 00
Feb  4 00:30:25 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 38 66 48 40 a0 01 00 01 00 00
Feb  4 00:30:25 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 38 67 48 40 a0 01 00 01 00 00
Feb  4 00:30:25 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 c0 38 68 48 40 a0 01 00 00 00 00
Feb  4 00:30:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 50 6c 49 40 a0 01 00 01 00 00
Feb  4 00:30:26 freenas (ada2:ahcich2:0:0:0): CAM status: Uncorrectable parity/CRC error
Feb  4 00:30:26 freenas (ada2:ahcich2:0:0:0): Retrying command
Feb  4 00:30:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 50 6d 49 40 a0 01 00 01 00 00
Feb  4 00:30:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 c0 50 6e 49 40 a0 01 00 00 00 00
Feb  4 00:30:49 freenas daemon[3136]:	 2018/02/04 00:30:49 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:32:50 freenas daemon[3136]:	 2018/02/04 00:32:50 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:34:50 freenas daemon[3136]:	 2018/02/04 00:34:50 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:36:25 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 c0 12 f8 40 a0 01 00 01 00 00
Feb  4 00:36:25 freenas (ada2:ahcich2:0:0:0): CAM status: Uncorrectable parity/CRC error
Feb  4 00:36:25 freenas (ada2:ahcich2:0:0:0): Retrying command
Feb  4 00:36:25 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 c0 13 f8 40 a0 01 00 01 00 00
Feb  4 00:36:25 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 10 c0 14 f8 40 a0 01 00 00 00 00
Feb  4 00:36:25 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 d0 14 f8 40 a0 01 00 01 00 00
Feb  4 00:36:25 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 90 d0 15 f8 40 a0 01 00 00 00 00
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): CAM status: Uncorrectable parity/CRC error
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): Retrying command
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 60 16 f8 40 a0 01 00 01 00 00
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 60 17 f8 40 a0 01 00 01 00 00
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 60 18 f8 40 a0 01 00 01 00 00
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 60 19 f8 40 a0 01 00 01 00 00
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 a0 60 1a f8 40 a0 01 00 00 00 00
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 00 1b f8 40 a0 01 00 01 00 00
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 00 1c f8 40 a0 01 00 00 00 00
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 08 1c f8 40 a0 01 00 01 00 00
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 90 08 1d f8 40 a0 01 00 00 00 00
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 98 1d f8 40 a0 01 00 01 00 00
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 98 1e f8 40 a0 01 00 01 00 00
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 98 1f f8 40 a0 01 00 01 00 00
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 18 98 20 f8 40 a0 01 00 00 00 00
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 28 48 f7 f7 40 a0 01 00 00 00 00
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 80 b0 20 f8 40 a0 01 00 00 00 00
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 80 c0 11 f8 40 a0 01 00 00 00 00
Feb  4 00:36:26 freenas (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 80 40 12 f8 40 a0 01 00 00 00 00
Feb  4 00:36:50 freenas daemon[3136]:	 2018/02/04 00:36:50 [WARN] agent: Check 'freenas_health' is now warning
Feb  4 00:38:50 freenas daemon[3136]:	 2018/02/04 00:38:50 [WARN] agent: Check 'freenas_health' is now warning
	Stop refresh
Everything is brand new, and the FreeNAS alert system light is green, also checked the storage and the status says HEALTHY.
Now I'm kind of lost, don't know where to start really, any tips?
kind regards
Marcin
Chris Moore
Those aren't really warnings. It's just a little bug that they're working on fixing. Should be fixed in the next release.
The "Check 'freenas-health' is warning" is a bug, but the "CAM status: Uncorrectable parity/CRC error" is most definitely an error. Most likely cabling.
Chris Moore
My mistake, I didn't see that part of the message through my phone.
@smartyarts What kind of cabling are you using? I agree with @danb35 , the cabling is usually at fault with the CRC errors. I had a build a few years ago where one of my cables was bad. I had to throw it out and use a different cable because, no matter which drive I used it with, it always caused errors like this.
smartyarts
I'm using the brand new sata cables that came with the Supermicro Motherboard. I'm plugin them into a 4bay Raidsonic Backplane (this one https://goo.gl/images/zRCcEJ) though. Maybe cleaning would help a little as the insides were very dusty when I looked inside before putting the new drives in. I will try to change to a different cable as well. So if it's the cable fault and I exchange it, everything should be normal and I do not have to do anything else?
Chris Moore
Making sure that the connectors are clean is a possible solution. Was it a used part?
smartyarts
I bought the backplanes brandnew in 2006 and used it since then. They never failed me...
Chris Moore
How many years ago was that?
Until now.
If everything gets a really good cleaning and then it works, that will be great, but I wouldn't say that something is reliable just because it has worked for the last 12 years. What that means is that it could fail any second, not that it will last forever.
wblock
Documentation Engineer
2006 was the big year of the great capacitor plague. Maybe not relevant, unless there are electrolytic capacitors in those backplanes. A visual inspection for capacitors with bulging tops is worthwhile. However, they can fail without bulging, too.
Chris Moore
wblock
Might be on the back of the board, but agreed, none visible. I'd sure want capacitors on that board.
smartyarts
I vacuum cleaned the backplanes and everything seems to work again. I already completed a burn in of the disks and so far so good no errors. Except the "Check 'freenas_health' is now warning" is still there in the bottom console. Thanks for your help!
smartyarts
ok, so this is really strange. As I wrote before I had no errors after the burn in of the HDs, however as soon as I started to copy data to them the console displayed the CAM status: Uncorrectable parity/CRC error again. So I finally replaced the cable for that particular drive and so far no errors appearing in the console! Thanks again for the hint!
smartyarts
CAM status: Uncorrectable parity/CRC error is back although I replaced the cable. So I tried a different slot of my second backplane, and the error came up again, which I find to be really strange. It seems the drive doesn't like to be connected to a backplane at all. o_O So I bypassed the backplane and hooked up the drive directly to the SATA port and so far no errors...
I realized that when I started to copy data to the FreeNAS pool that transfer speed would not go above 11.586 kbytes/s - it didn't do that before over a CIFS share on my Supermicro motherboard?!
smartyarts
So my network adapter would default to 100Mbit instead of 1000Mbit. I changed the network cable and it is back to Gigabit speed again.
