I have two esxi 6.7 hosts in a HA cluster. No DR and no vDS licensing.
Each hosts has a dual SPF+ nic cards, a single SFP+ card and the onboard 1gb ethernet.
Each host has a single DAC cable from each of the dual SFP+ cards plugged directly into another SFP+ card that belongs to theTrueNAS device. After creating the iscsi targets on the TrueNAS, I am able to see the iscsi extents / zvols on each esxi host. However, If I mount an extent and create a vmfs on esxi host A, I cannot add the same vmfs volume on host B. I do not own an SFP+ switch so I would like to have 10G direct connection from the hosts to the storage container as if I was emulating HBA eternal cards. I'm more familiar with HBA external and NFS file sharing so this concept of using NICs as HBAs is a good brain teaser. I used this article to help setup the configuration but it appears the author's tutorial only uses one host. In the comments, one person talks how this will work for devices in clusters using vSphere (which I'm have) but I cannot find any support documentation that explains how to accomplish this.
Any help with this would be greatly appreciated.
