OS: TrueNAS-12.0-U7
MB: GIGABYTE H370M DS3H
CPU: Intel i5 8500
RAM: 4x8GB (32GB) DDR4 2400 (NON-ECC)
HBA: SAS9211-8I 8PORT Int 6GB (in IT Mode) <- in a PCIe 4x slot
NIC (Management): Onboard Intel
NIC (iscsi): dual Intel 82599 SFP+
Case: SilverStone RM21-308
PSU: 600watt
Looked for previous posts but came up dry, feel free to point me to a thread if one really does exist.
Moving my esxi datastores from NFS to iscsi. In this process, I removed my two SFP+ from the switch and connected each port to the esxi host for iscsi.
Was wondering if I am able to move the data from the datasheet to the zvol. Data is located on the same pool.
If this isn't possible, what would you suggest being the safest - efficient way of moving this?
The only other option I can think of is using the 1Gb/s management nic to mount the datasheets as NFS and then use esxi to copy the data from each nfs to the vmfs datastores. This is just over 15tb of data and feel like that would take forever.
CPU: Intel i5 8500
PSU: 600watt
