Unable to install qbittorrent
Octopuss
I am probably doing something wrong, but I have no idea what.
When I try to install qbittorrent, it's stuck at "50.00% - net-p2p/qbittorrent" for quite some time, and then fails with this error:
"[EFAULT] Exception: RuntimeError: + Acquiring DHCP address: FAILED, address received: 0.0.0.0/8 Stopped qbittorrent due to DHCP failure occured, destroyed qbittorrent."
I have FreeNAS running in a VM and simply expected the plugin to get an IP address from the DHCP server.
Is that wrong assumption and I need to do something specific?
D
dlavigne
Guest
Which FreeNAS version? Also, what is the output of ifconfig ?
Octopuss
Latest version of course.
Shell doesn't seem to understand Ctrl+C so I can't paste it here.
Octopuss
Ok, SSH worked.
vmx0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 15 00
options=60039b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,TS O6,RXCSUM_IPV6,TXCSUM_IPV6>
ether 00:0c:29:20:7c:a3
hwaddr 00:0c:29:20:7c:a3
inet 192.168.2.6 netmask 0xffff0000 broadcast 192.168.255.255
media: Ethernet autoselect
status: active
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
groups: lo
ether 02:66:06:5d:dd:00
nd6 options=1<PERFORMNUD>
groups: bridge
member: vmx0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 2000
Jailer
Not strong, but bad
Octopuss
FreeNAS is virtualized. It's running under ESXi.
Octopuss
Well?
Octopuss
Looks like this happens when I try to create ANY jail.
Someone help!
bbenz3
I am having the same issue and I am starting to wonder if it has something to do with the ESXi virualized hardware.
bbenz3
I just got my issue fixed and maybe you have the same one.
Likely covered / thought of, but doesn't the Port Group assigned to the FreeNAS VM need to contain both the following with VNET?
  • Promiscuous mode = Accept (or "Inherit from vSwitch" provided set there)
  • Forged trasmits = Accept (or "Inherit from vSwitch" provided set there)
Octopuss
bbenz3
Octopuss
I just hope it's not a bad security practice or something.
Plus the network settings in ESXi is still pure mystery to me. Virtual swiches, groups,... jesus, my head is like a baloon just thinking about it.
bbenz3
I don't think it is a big deal. If you really wanted to change it around for security reasons you could isolate the one port the FreeNAS was connected to and move everything else to a separate vswitch. However for a home network I don't think that it's anything to worry about.
Octopuss
This assumes you have more than two LAN ports available I guess. I could do this later when I get a 10Gb card, but right now one port is simply the entire local network, so I think that wouldn't be possible.
I need a friend who is into virtualization and networking, heh.
bbenz3
I actually have one of those I can reach out to but I think I have figured out how to do it the correct way. First you create a new port group just for the FreeNAS box and you setup the security on it so that it function the expected way. Then you connect that port group to the switch that has your internal LAN physical nic attached. Essentially you are creating multiple port groups on a single virtual switch thus allowing you to setup different security architectures on the different port groups.
mattheja
I'd like to bump this thread. It fixed my issue with my FreeNAS/ESXi box, where I could not get my jails to have network access outside the FreeNAS VM.
This blog post from my man Chris Wahl explains the missing gap. I took tcpdumps, and could not figure out why my vSwitch was dropping my packets from the jail, then I stumbled across the thread, which triggered my brain for a post I read on Wahl's blog earlier. It all makes sense.
I was hoping this would fix it for me, since it sounded exactly the same. But sadly enough I still have the same error :(
Error: [EFAULT] + Acquiring DHCP address: FAILED, address received: 0.0.0.0/8 Stopped testjail due to DHCP failure.
Have you maybe done some other things to get it to work properly?
I have my ESXI on a static ip ending in 66
FreeNAS is on static 67
And I decided to turn it on for both my vSwitch as my port group
mattheja
Looking over my configuration, my port groups are set like this:
Security policy
Allow promiscuous mode
Yes
Allow forged transmits
Yes
Allow MAC changes
No
While my vSwitch with my port groups is running default settings (all security policies set to No).
If this does not work, tell me your full networking configuration and connectivity. Any vlans or DHCP relay?
