Hello all,
I'm sorry to post yet another thread with regards to VLAN's. I thought I had it all worked out when I got it working in my 11.3 BETA1 environment, but I can't get it to work in my 11.2U6 setup.
So I have a iocage jail called test2, using vnet. It's configured for VLAN ID 178. I am able to ping devices connected to the bridge, like the VLAN178 interface IP, but I can't seem to get beyond the bridge. Although.. test2 does get an IP address for my gateway using DHCP, eventhough I can't ping the router after getting an IP. From the Freenas self, I'm able to ping both the test2 and the gateway on vlan 178.
The test2 jail is fresh out of the box, so no firewall configured. 'allow_raw_sockets' is checked.
To clarify (hopefully) what does and does not work:
ifconfig freenas:
ifconfig test2:
Since, to me at least, this seems weird, I tried rebooting the freenas on various occasions, but to no avail.
As far as I can see, the vlan itself is kinda working but as mentioned: from the jail itself, I can't seem to get past the bridge with neither PING, nor HOST, etc.
Thanks for reading my issue, hope you can help!
Ping from freenas:
gateway 192.168.178.1 <<< works <<< freenas 192.168.178.42 >>> works >>> test2 192.168.178.101 (DHCP)
Ping from test2:
gateway 192.168.178.1 <<< fails <<< test2 192.168.178.101 (DHCP) >>> works >>> freenas 192.168.178.42
Set-up connectivity:
test2 (epair0b/vnet0.10) >>> bridge178 >>> vlan178 (bridge member) >>> re0 (parent for vlan178)
ifconfig freenas:
vlan178: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=80001<RXCSUM,LINKSTATE>
        ether 70:85:c2:01:ea:c4
        inet 192.168.178.42 netmask 0xffffff00 broadcast 192.168.178.255
        media: Ethernet autoselect (1000baseT <full-duplex>)
        status: active
        vlan: 178 vlanpcp: 0 parent interface: re0
        groups: vlan
bridge178: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        ether 02:3e:03:85:ac:b2
        nd6 options=1<PERFORMNUD>
        groups: bridge
        member: vnet0:10 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 15 priority 128 path cost 2000
        member: vlan178 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 3 priority 128 path cost 20000
vnet0:10: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: test2 as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:4b:48:3c
        hwaddr 02:22:d0:00:0f:0a
        status: active
        groups: epair
...ifconfig test2:
    options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
    inet6 ::1 prefixlen 128
    inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
    groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=8<VLAN_MTU>
    ether 02:ff:60:4b:48:3d
    hwaddr 02:22:d0:00:10:0b
    inet 192.168.178.101 netmask 0xffffff00 broadcast 192.168.178.255
    status: active
    groups: epairSince, to me at least, this seems weird, I tried rebooting the freenas on various occasions, but to no avail.
