iocage VMs and multiple bridges problems
Mark WatIng
Hi all,
Very new to networking so I might be doing something wrong here..... I'm on FreeNAS 11.1-Release
Anyway setup 2 VM's and using iocage for plex and a basic FreeBSD.
When setting up, FreeNAS creates two bridges one for iocage (includes vnets) and one for the VM's (includes tap0, tap1).
Problem is that my physical ethernet adapter can only be assigned to one bridge (which FreeNAS assigns to the VM bridge), and this means that my jails cannot access the internet.
The only solution I have found is once FreeNAS has booted, destroy the bridge containing tap0, tap1, bge1(ethernet adapter), and then assign them to bridge0 which is where my vnets are.
Question is - is this normal, or am I missing something here - appreciate any help please? Thank you!
My ifconfig output after boot :
bge0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=c019b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,VLAN_HWTSO,LINKSTATE>
	ether d0:bf:9c:45:0c:88
	hwaddr d0:bf:9c:45:0c:88
	media: Ethernet autoselect
bge1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=c0099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE>
	ether d0:bf:9c:45:0c:89
	hwaddr d0:bf:9c:45:0c:89
	inet 192.168.1.64 netmask 0xffffff00 broadcast 192.168.1.255
	media: Ethernet autoselect (100baseTX <full-duplex>)
	status: active
	options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
	inet6 ::1 prefixlen 128
	inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
	groups: lo
	ether 02:7e:d7:d1:a7:00
	nd6 options=1<PERFORMNUD>
	groups: bridge
	member: vnet0:2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 6 priority 128 path cost 2000
	member: vnet0:1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 5 priority 128 path cost 2000
vnet0:1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	description: associated with jail: plex
	options=8<VLAN_MTU>
	ether 02:ff:60:14:fa:09
	hwaddr 02:d4:50:00:05:0a
	status: active
	groups: epair
vnet0:2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	description: associated with jail: FreeBSD_iocage
	options=8<VLAN_MTU>
	ether 02:ff:60:4a:02:51
	hwaddr 02:d4:50:00:06:0a
	status: active
	groups: epair
bridge1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
	ether 02:7e:d7:d1:a7:01
	groups: bridge
	member: tap1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 10 priority 128 path cost 2000000
	member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 9 priority 128 path cost 2000000
	member: bge1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 2 priority 128 path cost 200000
tap0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=80000<LINKSTATE>
	ether 00:bd:d1:96:f8:00
	hwaddr 00:bd:d1:96:f8:00
	status: active
	groups: tap
	Opened by PID 6482
tap1: flags=8903<UP,BROADCAST,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	ether 00:bd:2c:97:f8:01
	hwaddr 00:bd:2c:97:f8:01
	status: no carrier
	groups: tap
My modified working ifconfig :
	status: active
	groups: lo
	groups: bridge
			ifmaxaddr 0 port 7 priority 128 path cost 2000000
	options=8<VLAN_MTU>
	status: active
	groups: epair
	options=8<VLAN_MTU>
	status: active
	groups: epair
	ether 00:bd:6c:8d:f8:00
	hwaddr 00:bd:6c:8d:f8:00
	status: active
	groups: tap
	Opened by PID 5276
	ether 00:bd:fe:8d:f8:01
	hwaddr 00:bd:fe:8d:f8:01
	status: no carrier
	groups: tap
Thanks,
Mark.
D
dlavigne
Guest
Sounds like a bug. Please create a report at bugs.freenas.org and post the issue number here.
Mark WatIng
Ok Thanks - I have logged the bug here :-
Issue #27780 created.
lukyjay
Can you please shed some light on how you fixed this issue, i.e. what commands you used to fix your ifconfig? I'm currently experiencing this problem.
Mark WatIng
Sure - health warning though, I'm not a network admin so don't know if my changes are correct from a purist point of view - but it does work.... see below the changes I made
ifconfig bridge1 destroy
ifconfig bridge0 addm tap1
ifconfig bridge0 addm tap0
ifconfig bridge0 addm bge1
I basically added all the adapters to a single bridge and destroyed the other bridge.
holt
Just want to say thanks. Your solution helped me :)
Had created a VM and after a freenas reboot all my vnet jails had no internet access.
Mark WatIng
cool :smile:
short-stack
This is a known bug, and is scheduled to be fixed soon. https://redmine.ixsystems.com/issues/30276#change-224078
But now (11.2-BETA1 and 11.2-BETA2) it does breaks in a totally different way.
This is because of a few things, Plex requires a VNET interface in the jail because it needs it's own MAC address to function. FreeNAS has/had an issue where as it was booting the VNET jail would be put on it's own bridge instead of the existing one, basically breaking everything.
The easiest thing I do to workaround it is set the Plex jail to not boot automatically. Let FreeNAS boot up completely and then once it's running, manually start the VNET jail, it then gets added to the bridge appropriately. I have a ticket in for this as well, but it's currently private while they evaluate it.
D
dlavigne
Guest
It wouldn't hurt to open another ticket for the new breakage as we'd like to shake out most of the use cases before we go to RC status. If you create one at bugs.freenas.org, post the issue number here.
short-stack
I did, the second ticket is #40484.
Thanks!
