Hey guys, I have issues with establishing LACP link aggregation.
The GUI returns an error (see below) but the lagg0 interface shows up and is configurable if you ack the error message.
However the link never becomes active on an arista port-channel.
FreeNAS Version: FreeNAS-11.1-U4 (89e3d93bc).
FreeNAS adapter card is an Intel X520.
FreeNAS status error:
CRITICAL: May 4, 2018, 12:23 p.m. - These ports are not ACTIVE on LAGG interface lagg0: bxe0, bxe1. Please check cabling and switch
I've tried several settings and got arista support involved now. Any hint would be appreciated.
configuration on the Arista (already confirmed by Arista support):
FreeNAS ifconfig output:
GUI error message when creating a LACP lagg0 Interface:
localhost(config)#sh ver Arista DCS-7050TX-48-F Hardware version: 11.12 Serial number: J******** System MAC address: 001c.7183.7b29 Software image version: 4.19.3F Architecture: i386 Internal build version: 4.19.3F-6971068.4193F [..] localhost(config)#sh port-channel 1 Port Channel Port-Channel1: No Active Ports Configured, but inactive ports: Port Reason unconfigured ------------------ --------------------------- Ethernet35/1 Waiting in LACP Negotiation Ethernet36/1 Waiting in LACP Negotiation sh run: [..] interface Port-Channel1 description LACP to FreeNAS switchport access vlan 101 spanning-tree portfast ! interface Ethernet35/1 description LACP to FreeNAS IF01 flowcontrol receive on switchport access vlan 101 channel-group 1 mode active spanning-tree portfast ! interface Ethernet36/1 description LACP to FreeNAS IF02 flowcontrol receive on switchport access vlan 101 channel-group 1 mode active spanning-tree portfast !
bxe0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=527bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO> ether 00:0e:1e:5d:a3:d0 hwaddr 00:0e:1e:5d:a3:d0 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (10Gbase-SR <full-duplex>) status: active bxe1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=527bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO> ether 00:0e:1e:5d:a3:d0 hwaddr 00:0e:1e:5d:a3:d2 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (10Gbase-SR <full-duplex>) status: active lagg0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=527bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO> ether 00:0e:1e:5d:a3:d0 inet 10.0.0.100 netmask 0xffffff00 broadcast 10.0.0.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: active groups: lagg laggproto lacp lagghash l2,l3,l4 laggport: bxe0 flags=0<> laggport: bxe1 flags=0<>
Request Method: POST Request URL: http://192.168.10.100/admin/network/lagginterface/add/ Software Version: FreeNAS-11.1-U4 (89e3d93bc) Exception Type: ClientException Exception Value: [Errno 17] File exists Exception Location: /usr/local/lib/python3.6/site-packages/middlewared/client/client.py in call, line 421 Server time: Fri, 4 May 2018 12:23:12 +0200 Traceback Environment: Software Version: FreeNAS-11.1-U4 (89e3d93bc) Request Method: POST Request URL: http://192.168.10.100/admin/network/lagginterface/add/ Traceback: File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner 42. response = get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response 249. response = self._get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response 178. response = middleware_method(request, callback, callback_args, callback_kwargs) File "./freenasUI/freeadmin/middleware.py" in process_view 162. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 23. return view_func(request, *args, **kwargs) File "./freenasUI/freeadmin/options.py" in wrapper 210. return self._admin.admin_view(view)(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/django/utils/decorators.py" in _wrapped_view 149. response = view_func(request, *args, **kwargs) File "/usr/local/lib/python3.6/site-packages/django/views/decorators/cache.py" in _wrapped_view_func 57. response = view_func(request, *args, **kwargs) File "./freenasUI/freeadmin/site.py" in inner 142. return view(request, *args, **kwargs) File "./freenasUI/freeadmin/options.py" in add 369. mf.done(request=request, events=events) File "./freenasUI/network/forms.py" in done 940. notifier().start("network") File "./freenasUI/middleware/notifier.py" in start 202. return c.call('service.start', what, {'onetime': onetime}, **kwargs) File "./freenasUI/middleware/notifier.py" in start 202. return c.call('service.start', what, {'onetime': onetime}, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/client/client.py" in call 421. raise ClientException(c.error, c.errno, c.trace, c.extra) Exception Type: ClientException at /admin/network/lagginterface/add/ Exception Value: [Errno 17] File exists Request information GET No GET data POST Variable Value __all__ '' lagg_protocol 'lacp' lagg_interfaces 'bxe1' __form_id 'dialogForm_lagginterface' FILES No FILES data COOKIES Variable Value csrftoken '********' sessionid 'uyg2pls07tyrp4cybj9uo8uqrry3zup0' fntreeSaveStateCookie 'root%2Croot%2F151%2Croot%2F147%2Croot%2F146' META Variable Value
