I have an APC UPS with a network card in it speaking SNMP. I would much prefer to connect FreeNAS directly to the UPS and have it read status directly but I'm not seeing the necessary SNMP settings in the setup screen, can this be accomplished?
I also have pfSense for a router for the site and it has NUT running on it and it can see the UPS and appears to work fine. How do I get FreeNAS to connect to either the UPS directly via SNMP or the NUT daemon running in pfSense? Help in section 11.17 doesn't seem useful at all. I attempted to connect FreeNAS to pfSense but I'm getting these errors and isn't working.
Request Method: POST Request URL: http://10.0.1.23/admin/services/ups/edit/1/ Software Version: FreeNAS-11.1-U6 (caffd76fa) Exception Type: CallTimeout Exception Value: Call timeout Exception Location: /usr/local/lib/python3.6/site-packages/middlewared/client/client.py in call, line 429 Server time: Wed, 7 Nov 2018 09:15:51 -0500 Traceback Environment: Software Version: FreeNAS-11.1-U6 (caffd76fa) Request Method: POST Request URL: http://10.0.1.23/admin/services/ups/edit/1/ Traceback: File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner 42. response = get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response 249. response = self._get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response 178. response = middleware_method(request, callback, callback_args, callback_kwargs) File "./freenasUI/freeadmin/middleware.py" in process_view 162. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 23. return view_func(request, *args, **kwargs) File "./freenasUI/freeadmin/options.py" in wrapper 210. return self._admin.admin_view(view)(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/django/utils/decorators.py" in _wrapped_view 149. response = view_func(request, *args, **kwargs) File "/usr/local/lib/python3.6/site-packages/django/views/decorators/cache.py" in _wrapped_view_func 57. response = view_func(request, *args, **kwargs) File "./freenasUI/freeadmin/site.py" in inner 142. return view(request, *args, **kwargs) File "./freenasUI/freeadmin/options.py" in edit 571. mf.save() File "./freenasUI/services/forms.py" in save 815. started = notifier().restart("ups") File "./freenasUI/middleware/notifier.py" in restart 223. return c.call('service.restart', what, {'onetime': onetime}, **kwargs) File "./freenasUI/middleware/notifier.py" in restart 223. return c.call('service.restart', what, {'onetime': onetime}, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/client/client.py" in call 429. raise CallTimeout("Call timeout") Exception Type: CallTimeout at /admin/services/ups/edit/1/ Exception Value: Call timeout Request information GET No GET data POST Variable Value __all__ '' ups_mode 'slave' ups_identifier 'APC' ups_remotehost '10.0.1.1' ups_remoteport '3493' ups_driver '' ups_port '' ups_options '' ups_optionsupsd '' ups_description 'Connect to pfSense to NUT' ups_shutdown 'batt' ups_shutdowntimer '300' ups_shutdowncmd '/sbin/shutdown -p now' ups_nocommwarntime '300' ups_monuser 'admin' ups_monpwd 'ironwolfCount0' ups_extrausers '' ups_emailnotify 'on' ups_toemail 'scottjal@gmail.com' ups_subject 'UPS report generated by %h' __form_id 'dialogForm_ups' FILES No FILES data COOKIES Variable Value csrftoken '********' fntreeSaveStateCookie 'stuff' sessionid 'c78uxj81wbi3kht41da8nju' META Variable Value
