problem after upgrade to 11.1-u7
donmay
Hi all .. i need urgent help please..i made an upgrade to freenas 11.2-uz.. and i keep on getting this error
Environment:
Software Version: FreeNAS-11.1-U7 (b45bfcf29)
Request Method: GET
Request URL: https://192.168.250.242/admin/servi.../?inline=true&dojo.preventCache=1576018755610
Traceback:
File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py" in execute
64. return self.cursor.execute(sql, params)
File "./freenasUI/freeadmin/sqlite3_ha/base.py" in execute
412. execute = self.locked_retry(Database.Cursor.execute, query, params)
File "./freenasUI/freeadmin/sqlite3_ha/base.py" in locked_retry
389. rv = method(self, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner
42. response = get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response
249. response = self._get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response
178. response = middleware_method(request, callback, callback_args, callback_kwargs)
File "./freenasUI/freeadmin/middleware.py" in process_view
162. return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
23. return view_func(request, *args, **kwargs)
File "./freenasUI/freeadmin/options.py" in wrapper
210. return self._admin.admin_view(view)(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/django/utils/decorators.py" in _wrapped_view
149. response = view_func(request, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/django/views/decorators/cache.py" in _wrapped_view_func
57. response = view_func(request, *args, **kwargs)
File "./freenasUI/freeadmin/site.py" in inner
142. return view(request, *args, **kwargs)
File "./freenasUI/freeadmin/options.py" in edit
722. content_type='text/html')
File "/usr/local/lib/python3.6/site-packages/django/shortcuts.py" in render
30. content = loader.render_to_string(template_name, context, request, using=using)
File "/usr/local/lib/python3.6/site-packages/django/template/loader.py" in render_to_string
68. return template.render(context, request)
File "/usr/local/lib/python3.6/site-packages/django/template/backends/django.py" in render
66. return self.template.render(context)
File "/usr/local/lib/python3.6/site-packages/django/template/base.py" in render
208. return self._render(context)
File "/usr/local/lib/python3.6/site-packages/django/template/base.py" in _render
199. return self.nodelist.render(context)
994. bit = node.render_annotated(context)
File "/usr/local/lib/python3.6/site-packages/django/template/base.py" in render_annotated
961. return self.render(context)
File "/usr/local/lib/python3.6/site-packages/django/template/loader_tags.py" in render
61. result = self.nodelist.render(context)
File "./freenasUI/freeadmin/templatetags/freeadmin.py" in render
52. adv_mode = Advanced.objects.order_by('-id')[0].adv_advancedmode
File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py" in __getitem__
295. return list(qs)[0]
File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py" in __iter__
256. self._fetch_all()
File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py" in _fetch_all
1087. self._result_cache = list(self.iterator())
54. results = compiler.execute_sql()
File "/usr/local/lib/python3.6/site-packages/django/db/models/sql/compiler.py" in execute_sql
835. cursor.execute(sql, params)
File "/usr/local/lib/python3.6/site-packages/django/db/utils.py" in __exit__
94. six.reraise(dj_exc_type, dj_exc_value, traceback)
File "/usr/local/lib/python3.6/site-packages/django/utils/six.py" in reraise
685. raise value.with_traceback(tb)
Exception Type: OperationalError at /admin/services/iscsitargetglobalconfiguration/edit/1/
Exception Value: no such column: system_advanced.adv_consolescreensaver
i acnnot access the shares nor can i access certain pages of freenas...please how do i resolve this issue ?
