Hello there.
Having updated to FreeNAS-11.2-U3, I can no longer create jails.
This is how I attempt to create the jail:
Jail -> Add (Name: foobar, Release 11.2) -> Next (DHCP autoconfigure IPv4)-> Submit
I get the error invalid literal for int() with base 10: 'None'
I can create jaild from the CLI like this:
Any ideas as to why this is happening?
Error: concurrent.futures.process._RemoteTraceback:
  File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
    r = call_item.fn(*call_item.args, **call_item.kwargs)
  File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 128, in main_worker
    res = loop.run_until_complete(coro)
  File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
    return future.result()
  File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 88, in _run
    return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
  File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 81, in _call
    return methodobj(*params)
  File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 156, in create_job
    dc_config = self.middleware.call_sync('domaincontroller.config')
  File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 100, in call_sync
    return self.client.call(method, *params, timeout=timeout, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/middlewared/client/client.py", line 451, in call
    raise c.py_exception
ValueError: invalid literal for int() with base 10: 'None'
The above exception was the direct cause of the following exception:
  File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 332, in run
    await self.future
  File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 356, in __run_body
    rv = await self.middleware._call_worker(self.serviceobj, self.method_name, *self.args, job={'id': self.id})
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1105, in _call_worker
    job,
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1036, in run_in_proc
    return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1021, in run_in_executor
ValueError: invalid literal for int() with base 10: 'None'I can create jaild from the CLI like this:
root@ultraman:~ # iocage create -r 11.2-RELEASE -n jailfromcli boot=on jailfromcli successfully created! * Starting jailfromcli + Started OK + Starting services OK
