I finally upgraded from FN-9 to 11.2 and I'm trying to recreate my jails to move to the new iocage.
Then I get this error:
- Create a new jail
- Set a name
- Release = 11.2-RELEASE
- Click NEXT
- Select DHCP (VNET gets automatically selected)
- Click NEXT
- Review options
- Click SUBMIT
Jail Summary Jail Name : my_jail Release : 11.2-RELEASE DHCP Autoconfigure IPv4 : Yes VNET Virtual Networking : Yes Confirm these settings.
""" Traceback (most recent call last): File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker r = call_item.fn(*call_item.args, **call_item.kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 128, in main_worker res = loop.run_until_complete(coro) File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete return future.result() File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 88, in _run return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 81, in _call return methodobj(*params) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 81, in _call return methodobj(*params) File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 156, in create_job dc_config = self.middleware.call_sync('domaincontroller.config') File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 100, in call_sync return self.client.call(method, *params, timeout=timeout, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/client/client.py", line 451, in call raise c.py_exception ValueError: invalid literal for int() with base 10: 'None' """ The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 332, in run await self.future File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 356, in __run_body rv = await self.middleware._call_worker(self.serviceobj, self.method_name, *self.args, job={'id': self.id}) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1105, in _call_worker job, File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1036, in run_in_proc return await self.run_in_executor(self.__procpool, method, *args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1021, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) ValueError: invalid literal for int() with base 10: 'None'
