[BUG] invalid literal for int() with base 10: 'None'
MtK
I finally upgraded from FN-9 to 11.2 and I'm trying to recreate my jails to move to the new iocage.
  • Create a new jail
  • Set a name
  • Release = 11.2-RELEASE
  • Click NEXT
  • Select DHCP (VNET gets automatically selected)
  • Click NEXT
  • Review options
  • Click SUBMIT
Jail Summary
Jail Name : my_jail
Release : 11.2-RELEASE
DHCP Autoconfigure IPv4 : Yes
VNET Virtual Networking : Yes
Confirm these settings.
Then I get this error:
  File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
    r = call_item.fn(*call_item.args, **call_item.kwargs)
  File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 128, in main_worker
    res = loop.run_until_complete(coro)
  File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
    return future.result()
  File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 88, in _run
    return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
  File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 81, in _call
    return methodobj(*params)
  File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 156, in create_job
    dc_config = self.middleware.call_sync('domaincontroller.config')
  File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 100, in call_sync
    return self.client.call(method, *params, timeout=timeout, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/middlewared/client/client.py", line 451, in call
    raise c.py_exception
ValueError: invalid literal for int() with base 10: 'None'
The above exception was the direct cause of the following exception:
  File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 332, in run
    await self.future
  File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 356, in __run_body
    rv = await self.middleware._call_worker(self.serviceobj, self.method_name, *self.args, job={'id': self.id})
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1105, in _call_worker
    job,
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1036, in run_in_proc
    return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1021, in run_in_executor
D
dlavigne
Guest
Were you able to resolve this? If not, which exact versions did you update from and to (eg did you jump from 9.10 to 11.2-U3 in one update or over a series of updates)?
kasak
Nope, i was not able to resolve this. I have not jumped from 9.10. I was using 9.10 and after i updated to 11.2-release. I’m updating every minor release.
I’ve tried to fetch jail with shell: iocage fetch. But it doesn’t help
Chris Moore
You misunderstood the question. You skipped over version 11.0 and 11.1, which was the point of the question.
hungarianhc
Just searched for my error I just got. Found myself on this thread. I'm having the same issue.
craig288
I have the same issue after having upgraded from 9.10 to 11.2U3. I do have legacy jails but I have stopped them and intend to create them new using iocage but I when I try I get the same error as is being reported here.
malcomvx
Sometimes the difference between Python2.x and Python3.x that leads to this ValueError: invalid literal for int() with base 10 . With Python2.x , int(str(3/2)) gives you "1". With Python3.x , the same gives you ("1.5"): ValueError: invalid literal for int() with base 10: "1.5".
