ExR90
- Sep 30, 2017
I cannot connect to any SMB shares on this system since upgrading to 13.0-U3.1. Regardless if I use hostname or IP, I do not even get far enough to get prompted for credentials. I just rather quickly get a pop-up saying "There was a problem connecting to the server IPADDRESS" and "The server may not exist or it is unavailable at this time...........".
I CAN access these shares from windows machines just fine. Interestingly I CAN connect to SMB shares on a different TrueNAS Core system running exact same version of Truenas Core, so I am not sure if the version upgrade is related. I can't determine what the difference is between them. I have tried enabling the Mac SMB extensions (and restarting SMB) without any change.
Even weirder, if I run a terminal window on the Mac, then use smbutil, I CAN see the shares and if I use mount_smbfs to mount the share that way it works fine there too. I thought this might be a MacOS UI issue, but it connects to the other system fine. Very odd.
Ideas?
MacOS 13.1
TrueNAS core 13.0-U3.1
Ideas?
MacOS 13.1
