Unable to connect to old share after clean FreeNAS install
usp97
I recently wasn't able to connect to my FreeNAS, so I borrowed a monitor from work to see what the problem was. I found an error that turned out to be an issue with one of my 2 drives. In trying to find out what the problem was, I did a clean install of FreeNAS on the USB drive. Eventually, I was able to get it booted up, but only using 1 of the 2 drives. When I went to the GUI, it made me set up a new share. For some reason, I can connect to the drive, but not the old folders. When I use the GUI, I can see the old folder structure and their sizes, so I know the information is still available. I am looking for a way to get to the old folders and temporarily transfer the files to an external drive, so I can get 2 new drives for the NAS.
Thank you for any help you are able to give.
Matthew
SweetAndLow
Sweet'NASty
Describe what you have tried to do and what error messages you are getting.
usp97
Attached is a pic of the error I was getting. When I looked into it, I found that was possibly a connection issue to one of my drives. I attempted to start up with each drive in alone and with no drive in, but nothing worked. I installed a new copy of FreeNAS and tried again. I found that I could boot up with one of the drives, but the GUI made me go through the setup wizard and create a new share. I can see the new and old share in the GUI, but I can't access the old share from my computer. I want to get my files off, so I can start over with 2 new drives.
usp97
anodos,
I am at work right now, so I will do this when I get home. Just to be safe and speed this thread up, can you give me a quick overview of how to output the 'zfs list' and 'zpool status'?
usp97
[root@freenas ~]# zpool status
pool: FreeNAS
state: DEGRADED
status: One or more devices could not be opened. Sufficient replicas exist for
the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
see: http://illumos.org/msg/ZFS-8000-2Q
scan: scrub repaired 0 in 0h51m with 0 errors on Sun Aug 7 00:53:22 2016
NAME STATE READ WRITE CKSUM
FreeNAS DEGRADED 0 0 0
mirror-0 DEGRADED 0 0 0
8306981635671541791 UNAVAIL 0 0 0 was /dev/gptid/dafce66f-9719-11e5-890d-28924a360
5b4
gptid/db8d12ec-9719-11e5-890d-28924a3605b4 ONLINE 0 0 0
errors: No known data errors
pool: freenas-boot
state: ONLINE
scan: none requested
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
Also, I just tried to connect to the drive and it came up with "Select the volumes you want to mount on '192.168.1.70':". It gives me the choice of homes and root, but neither will connect.
