Unable to access the web interface for Transmission
ludicerza
I'm able to ping the IP address for Transmission, but unable to open the web interface using http://ipaddress:9091/
Am I using the correct port number? If so, what else can I do to troubleshoot this?
Joshua Parker Ruehlig
you're sure the ipaddress is that of the jail?
If so, you could run sockstat in the jail to see if anything is binding to port 9091. Ideally a process owned by the transmission user is.
ludicerza
Resolved this issue by creating a new volume and dataset with different permissions. After reinstalling the Bit Torrent plugin I was able to connect to the Transmission web interface using http://ipaddress:9091/
