uzelac
 - Jan 4, 2016
I'm no longer able to load the transmission web interface. I think this problem began when my server was restarted about two weeks ago, but I'm not 100% sure.
I set up openvpn and then performed minimal config of ipfw in my transmission jail. I never had a chance to finish my ipfw config so I stopped the service and went about my day. (It was still enabled in my rc.conf at this point.)
I was on vacation a couple weeks ago and my server stopped responding, so I had a close friend come and reboot it. When I came back from vacation, I noticed that the transmission interface was no longer accessible.
The first thing I did was make sure that both ipfw and openvpn were stopped and disabled in my rc.conf, in case something had gone haywire. I still wasn't able to connect to the interface.
I know that transmission is functioning. transmission-remote -l shows that I have torrents actively downloading. It's also communicating with CouchPotato and Sonarr.
Netstat shows that the jail is listening on port 9091:
ps ax shows that the daemon is running:
The only transmission-related entries in /var/log/messages are what I believe to be a utp-related error from when I rebooted my server about an hour ago.
In my transmission config, RPC is enabled and bound to 0.o.o.o, and the whitelist is disabled.
As much as I hate to admit it... I'm at a debugging loss.
I should clarify that this is a local server on the same LAN and also add that I'm an idiot who doesn't have a snapshot to restore from.
Any guidance is much appreciated!
# netstat -an | grep 9091 tcp4 0 0 192.168.1.5.9091 192.168.1.4.41072 TIME_WAIT tcp4 0 0 192.168.1.5.9091 192.168.1.4.10566 TIME_WAIT tcp4 0 0 192.168.1.5.9091 192.168.1.4.45148 TIME_WAIT tcp4 0 0 192.168.1.5.9091 192.168.1.4.55525 TIME_WAIT tcp4 0 0 192.168.1.5.9091 192.168.1.4.36705 TIME_WAIT tcp4 0 0 192.168.1.5.9091 192.168.1.4.52296 TIME_WAIT tcp4 0 0 192.168.1.5.9091 192.168.1.4.31135 TIME_WAIT tcp4 0 0 192.168.1.5.9091 192.168.1.4.10188 TIME_WAIT tcp4 0 0 192.168.1.5.9091 192.168.1.6.57911 ESTABLISHED tcp4 0 0 *.9091 *.* LISTEN
# ps ax PID TT STAT TIME COMMAND 9481 ?? SsJ 0:00.02 /usr/sbin/syslogd -s 9520 ?? SsJ 0:17.31 /usr/pbi/transmission-amd64/bin/transmission-daemon -g /var/db/transmission -x /var/run/transmission/daemon.pid 9529 ?? SsJ 0:24.36 /usr/local/sbin/openvpn --cd /usr/local/etc/openvpn --daemon openvpn --config /usr/local/etc/openvpn/openvpn.conf --writepid /var/run/openvpn.pid 9555 ?? SsJ 0:00.00 /usr/sbin/cron -s 10487 ?? IJ 0:00.85 /usr/pbi/transmission-amd64/bin/python2.7 /usr/pbi/transmission-amd64/control.py start 192.168.1.5 12348 34256 0 SJ 0:00.01 bash 34677 0 R+J 0:00.00 ps ax
Jan 5 18:38:36 transmission_1 transmission-daemon[9520]: UDP Failed to set receive buffer: No buffer space available (tr-udp.c:59) Jan 5 18:38:36 transmission_1 transmission-daemon[9520]: UDP Failed to set receive buffer: requested 4194304, got 42080 (tr-udp.c:78)
