Hi, I am having a severe issue.
I have setup a little nas box at work (FreeNAS-8.0.4-RELEASE-x86 (10351)) on a fresh 16gb Corsair drive (yes, overkill, but the original drive developed some physical errors--originally running FreeNAS-8.0.2).
Anyways, I reinstalled the original FreeNAS-8.0.2 first.
I was unable to auto-import/import my original volume (2x 500gb Western Digitals – Mirrored Array).
The issue is duplicated after installing FreeNAS-8.0.4-RELEASE-x86 (10351) as well.
The import command in the GUI gives me:
“The selected disks were not verified for this import rules” (yes, with the grammatical error). The auto-import shows a “workmirror [geom]” and refuses to import it with the same error.
Thanks to this issue, and the forums, I now know and tried the following:
< sysctl kern.disks > for disc info – ada0 and ada1
< camcontrol devlist >
< dmesg | more >
< gpart recover ada0 > spits back "invalid argument"
< gpart restore ada0 > appears to do nothing but give me a blank line
I tried mounting one of the drives...
< mount –uw/ >
<mk dir /mnt/temp >
< mount /dev/ada0/mnt/temp >
< cd mnt >, etc
^^the commands went through (I think those are exactly the same, but I didn’t really know what to do with afterward—tried to import again, but got the same issue error).
Running < gpart show > appears to show 3 MBR records (at this time, there is only one 500gb drive installed). And…to be honest, the entire screen confuses me.
The following post is interesting where the guy took out a few lines of code at the end of the post, but I have no idea how to do this…¿
http://forums.freenas.org/showthrea...he-existing-ufs-filesystem&highlight=line+441
Finally, I am currently attempting to scan one of the disks with UFS Explorer (http://www.uf***plorer.com/download.php); however, it appears that it will take the entire day to finish (emphasis on scan—not actual recovery). I have attached a screen shot of UFS Explorer--not sure why it is showing a NTFS partition (that it cannot access, nor can Windows XP).
This is very important for me, I have backups, but they are 1-2 months old (which amounts to a lot of work for me and my business).
Thank you in advance!
--Synaux
(p.s. I apologize if the answer is on the forums—I spent a solid 5-6 hours looking around).
< dmesg | more >
< mount –uw/ >
<mk dir /mnt/temp >
< cd mnt >, etc
--Synaux
