bettingmalaguti
- Oct 14, 2021
Hello everybody
I have got the following problem. My TrueNas system does not detect the attached 4 xHDD which are connected through the inbuild motherboard SFF-8643 connector.
Is this normal? Does TrueNas only detect PCI Card Adapters?
Should I use a PCI-E to SFF-8643 card to make it work properly?
Before I make additional spendings I would like to consider the above asked questions.
I really appreciate your help!
Thanks a lot.
Used Cable SFF-8643 to 4 x Sata
SAS 12G SFF-8643 to SATA Cable
PCI-E adapters I would consider:
PCIe 3.0 x4 Adapter SFF-8639
and
PCIe 2.0 X1 auf SATA III 4-Port
Thanks a lot.
and
- Asus Maximus VIII Impact Z170 LGA1151 ITX
- Intel i5 6600k
- DDR4 3600 Mhz
- Intel i5 6600k
- DDR4 3600 Mhz
