Tweaking my system - baselines - stumped on some numbers (PCIe Slot speeds vs actual)
MrGuvernment
Hello All,
As I lurk these forums often and read far too much, I finally got some time to do some testing on my set up (in sig)
Along with that, I added 2 more NVMe's to my VM pool.
Using FIO (all tests run local on TrueNAS via SSH), I began doing some testing of each NVMe to get an idea of performance before making my pool (4 NVMe 2x vdev for vms over NFS)
Note, the HP Z6 G4, is PCIe3 based, the part that has me stumped, if that I am getting faster than PCIe3 x4 speeds, when 3 of my NVMe are connected at that, as well, the BIOS is reporting some interesting numbers for the slots that seem wrong.
TLDR;Perhaps I am missing something, or completely am having a brain fart, but seems the speeds are reporting faster than physically possible on some ports.
HP Bios example:
Slot 3 PCIe x4 = Shows "Current PCIe Speed Gen3 (8Gbps)" - How is that possible when according to the manual Slot 3: PCI Express Gen3 x4 - PCH ?
The motherboard of my rig PCIe Slot config
PCI Express Connectors
Slot 0: Mechanical-only (2nd CPU connector)
Slot 1: PCI Express Gen3 x4 - CPU
Slot 2: PCI Express Gen3 x16 - CPU
Slot 4: PCI Express Gen3 x8 – CPU (slot converts to x4 electrical when SSD is installed in 2nd M.2 slot)*
Slot 5: PCI Express Gen3 x16 - CPU
Slot 6: PCI Express Gen3 x4 - PCH
M.2 Slot 1: M.2 PCIe Gen 3 x4 - CPU
M.2 Slot 2: M.2 PCIe Gen 3 x4 - CPU
My NVMe's are connected into: (those in PCIe slots using Sabrent adapter - https://sabrent.com/products/EC-PCIE)
Slot 3: PCI Express Gen3 x4 - PCH  - nvd4 - Boot Drive - 970 Evo NVMe
Slot 4: PCI Express Gen3 x8 - CPU - nvd0 - XPG 2TB GAMMIX S70 Blade - Should be at x4 because I have both m.2 slots populated
Slot 6: PCI Express Gen3 x4 - PCH - nvd1 XPG 2TB GAMMIX S70 Blade
M.2 Slot 1: M.2 PCIe Gen 3 x4 - CPU - nvd2 - Samsung 980 PRO 2TB NVMe
M.2 Slot 2: M.2 PCIe Gen 3 x4 - CPU - nvd3 - Samsung 980 PRO 2TB NVMe
So, on to the testing and what I used. Using Fio with some methods listed from the below link. Each drive tested as a solo drive.
### Sequential READ speed with big blocks QD32 (this should be near the number you see in the specifications for your drive):
fio --name TESTSeqRead --eta-newline=5s --filename=fio-tempfile-RSeq1.dat --rw=read --size=500m --io_size=50g --blocksize=1024k --fsync=10000 --iodepth=32 --direct=1 --numjobs=1 --runtime=60 --group_reporting
## Each NVMe one at a time - 100% CPU usage single core
nvd0    READ: bw=7170MiB/s (7518MB/s), 7170MiB/s-7170MiB/s (7518MB/s-7518MB/s), io=50.0GiB (53.7GB), run=7141-7141msec
nvd1    READ: bw=7168MiB/s (7516MB/s), 7168MiB/s-7168MiB/s (7516MB/s-7516MB/s), io=50.0GiB (53.7GB), run=7143-7143msec
nvd2    READ: bw=7238MiB/s (7589MB/s), 7238MiB/s-7238MiB/s (7589MB/s-7589MB/s), io=50.0GiB (53.7GB), run=7074-7074msec
nvd3    READ: bw=7156MiB/s (7503MB/s), 7156MiB/s-7156MiB/s (7503MB/s-7503MB/s), io=50.0GiB (53.7GB), run=7155-7155msec
## All 4 NVMe tested at the same time (script run against all 4 at the same time)  - 100% CPU usage single core for each
nvd0    READ: bw=6882MiB/s (7216MB/s), 6882MiB/s-6882MiB/s (7216MB/s-7216MB/s), io=50.0GiB (53.7GB), run=7440-7440msec
nvd1    READ: bw=6919MiB/s (7255MB/s), 6919MiB/s-6919MiB/s (7255MB/s-7255MB/s), io=50.0GiB (53.7GB), run=7400-7400msec
nvd2    READ: bw=6749MiB/s (7077MB/s), 6749MiB/s-6749MiB/s (7077MB/s-7077MB/s), io=50.0GiB (53.7GB), run=7586-7586msec
nvd3    READ: bw=6797MiB/s (7127MB/s), 6797MiB/s-6797MiB/s (7127MB/s-7127MB/s), io=50.0GiB (53.7GB), run=7533-7533msec
### Sequential WRITE speed with big blocks QD32 (this should be near the number you see in the specifications for your drive):
fio --name TESTSeqWrite --eta-newline=5s --filename=fio-tempfile-WSeq.dat --rw=write --size=500m --io_size=50g --blocksize=1024k --fsync=10000 --iodepth=32 --direct=1 --numjobs=1 --runtime=60 --group_reporting
nvd0 WRITE: bw=6465MiB/s (6780MB/s), 6465MiB/s-6465MiB/s (6780MB/s-6780MB/s), io=50.0GiB (53.7GB), run=7919-7919msec
nvd1 WRITE: bw=6544MiB/s (6862MB/s), 6544MiB/s-6544MiB/s (6862MB/s-6862MB/s), io=50.0GiB (53.7GB), run=7824-7824msec
nvd2 WRITE: bw=6278MiB/s (6583MB/s), 6278MiB/s-6278MiB/s (6583MB/s-6583MB/s), io=50.0GiB (53.7GB), run=8156-8156msec
nvd3 WRITE: bw=6456MiB/s (6770MB/s), 6456MiB/s-6456MiB/s (6770MB/s-6770MB/s), io=50.0GiB (53.7GB), run=7930-7930msec
## All 4 NVMe tested at the same time avg 86% CPU usage per core
nvd0 WRITE: bw=5988MiB/s (6278MB/s), 5988MiB/s-5988MiB/s (6278MB/s-6278MB/s), io=50.0GiB (53.7GB), run=8551-8551msec
nvd1 WRITE: bw=5989MiB/s (6280MB/s), 5989MiB/s-5989MiB/s (6280MB/s-6280MB/s), io=50.0GiB (53.7GB), run=8549-8549msec
nvd2 WRITE: bw=5467MiB/s (5733MB/s), 5467MiB/s-5467MiB/s (5733MB/s-5733MB/s), io=50.0GiB (53.7GB), run=9365-9365msec
nvd3 WRITE: bw=5553MiB/s (5823MB/s), 5553MiB/s-5553MiB/s (5823MB/s-5823MB/s), io=50.0GiB (53.7GB), run=9220-9220msec
### Random 4K read QD1 (this is the number that really matters for real world performance unless you know better for sure):
fio --name TESTRandom4kRead --eta-newline=5s --filename=fio-tempfile-RanR4K.dat --rw=randread --size=500m --io_size=50g --blocksize=4k --fsync=1 --iodepth=1 --direct=1 --numjobs=1 --runtime=60 --group_reporting
## Each NVMe one at a time  (script run against all 4 at the same time)  - 100% CPU usage single core
nvd0 READ: bw=1260MiB/s (1321MB/s), 1260MiB/s-1260MiB/s (1321MB/s-1321MB/s), io=50.0GiB (53.7GB), run=40627-40627msec
nvd1 READ: bw=1230MiB/s (1289MB/s), 1230MiB/s-1230MiB/s (1289MB/s-1289MB/s), io=50.0GiB (53.7GB), run=41639-41639msec
nvd2 READ: bw=1149MiB/s (1205MB/s), 1149MiB/s-1149MiB/s (1205MB/s-1205MB/s), io=50.0GiB (53.7GB), run=44552-44552msec
nvd3 READ: bw=1184MiB/s (1241MB/s), 1184MiB/s-1184MiB/s (1241MB/s-1241MB/s), io=50.0GiB (53.7GB), run=43245-43245msec
## All 4 NVMe tested at the same time - 100% CPU usage single core for each
nvd0 READ: bw=1087MiB/s (1140MB/s), 1087MiB/s-1087MiB/s (1140MB/s-1140MB/s), io=50.0GiB (53.7GB), run=47094-47094msec
nvd1 READ: bw=1088MiB/s (1141MB/s), 1088MiB/s-1088MiB/s (1141MB/s-1141MB/s), io=50.0GiB (53.7GB), run=47048-47048msec
nvd2 READ: bw=1114MiB/s (1168MB/s), 1114MiB/s-1114MiB/s (1168MB/s-1168MB/s), io=50.0GiB (53.7GB), run=45954-45954msec
nvd3 READ: bw=1104MiB/s (1158MB/s), 1104MiB/s-1104MiB/s (1158MB/s-1158MB/s), io=50.0GiB (53.7GB), run=46360-46360msec
### Mixed random 4K read and write QD1 with sync (this is worst case performance you should ever expect from your drive, usually less than 1% of the numbers listed in the spec sheet):
fio --name TESTRandom4kRW --eta-newline=5s --filename=fio-tempfile-RanRW4k.dat --rw=randrw --size=500m --io_size=10g --blocksize=4k --fsync=1 --iodepth=1 --direct=1 --numjobs=1 --runtime=60 --group_reporting
## Each NVMe one at a time - 15% or lower CPU usage
nvd0 READ: bw=13.3MiB/s (13.9MB/s), 13.3MiB/s-13.3MiB/s (13.9MB/s-13.9MB/s), io=796MiB (835MB), run=60001-60001msec
      WRITE: bw=13.2MiB/s (13.8MB/s), 13.2MiB/s-13.2MiB/s (13.8MB/s-13.8MB/s), io=792MiB (831MB), run=60001-60001msec
nvd1 READ: bw=13.5MiB/s (14.2MB/s), 13.5MiB/s-13.5MiB/s (14.2MB/s-14.2MB/s), io=810MiB (849MB), run=60000-60000msec
     WRITE: bw=13.4MiB/s (14.1MB/s), 13.4MiB/s-13.4MiB/s (14.1MB/s-14.1MB/s), io=806MiB (845MB), run=60000-60000msec
nvd2 READ: bw=1800KiB/s (1843kB/s), 1800KiB/s-1800KiB/s (1843kB/s-1843kB/s), io=105MiB (111MB), run=60001-60001msec
    WRITE: bw=1798KiB/s (1841kB/s), 1798KiB/s-1798KiB/s (1841kB/s-1841kB/s), io=105MiB (110MB), run=60001-60001msec
nvd3 READ: bw=1693KiB/s (1734kB/s), 1693KiB/s-1693KiB/s (1734kB/s-1734kB/s), io=99.2MiB (104MB), run=60002-60002msec
      WRITE: bw=1691KiB/s (1731kB/s), 1691KiB/s-1691KiB/s (1731kB/s-1731kB/s), io=99.1MiB (104MB), run=60002-60002msec
## All 4 NVMe tested at the same time (script run against all 4 at the same time)  - 15% or lower CPU usage
nvd0 READ: bw=13.3MiB/s (14.0MB/s), 13.3MiB/s-13.3MiB/s (14.0MB/s-14.0MB/s), io=800MiB (838MB), run=60001-60001msec
      WRITE: bw=13.3MiB/s (13.9MB/s), 13.3MiB/s-13.3MiB/s (13.9MB/s-13.9MB/s), io=796MiB (834MB), run=60001-60001msec
nvd1 READ: bw=13.8MiB/s (14.4MB/s), 13.8MiB/s-13.8MiB/s (14.4MB/s-14.4MB/s), io=825MiB (866MB), run=60001-60001msec
      WRITE: bw=13.7MiB/s (14.4MB/s), 13.7MiB/s-13.7MiB/s (14.4MB/s-14.4MB/s), io=822MiB (862MB), run=60001-60001msec
nvd2 READ: bw=1681KiB/s (1721kB/s), 1681KiB/s-1681KiB/s (1721kB/s-1721kB/s), io=98.5MiB (103MB), run=60002-60002msec
      WRITE: bw=1678KiB/s (1719kB/s), 1678KiB/s-1678KiB/s (1719kB/s-1719kB/s), io=98.3MiB (103MB), run=60002-60002msec
nvd3 READ: bw=1765KiB/s (1808kB/s), 1765KiB/s-1765KiB/s (1808kB/s-1808kB/s), io=103MiB (108MB), run=60001-60001msec
      WRITE: bw=1764KiB/s (1807kB/s), 1764KiB/s-1764KiB/s (1807kB/s-1807kB/s), io=103MiB (108MB), run=60001-60001msec
Now, when I created a pool with all 4 drives.. I seem capped to a single drives performance for some tests
VMs Pool - 4 NVMe Drives - 2 VDEVs mirrored
READ: bw=7407MiB/s (7767MB/s), 7407MiB/s-7407MiB/s (7767MB/s-7767MB/s), io=50.0GiB (53.7GB), run=6912-6912msec
WRITE: bw=6207MiB/s (6508MB/s), 6207MiB/s-6207MiB/s (6508MB/s-6508MB/s), io=50.0GiB (53.7GB), run=8249-8249msec
READ: bw=1157MiB/s (1213MB/s), 1157MiB/s-1157MiB/s (1213MB/s-1213MB/s), io=50.0GiB (53.7GB), run=44244-44244msec
  • HP Z6 G4 Specs.pdf
Arwen
I did not read through your long message. But, what I can see is that you have confused GB=GigaBytes per second with Gb=GigaBits per second.
HP Bios example:
PCIe gen 3 is 8GigaBits per second, per lane.
Here in the forums we have had quite a bit of confusion in that regard. So we prefer people write out Bytes or Bits to clarify what they mean.
MrGuvernment
So in the case of the HP Bios they are just reporting the "Per Lane" speed, not the total of the bandwidth (x4/x8/x16)
Now for speeds I am seeing 8Gbits = 1GByte perlane in PCIe3, but i should be capped still:
PCIe3 x4 = 4GBytes/s = 34Gbits/s = 4096MBytes/s Total for bandwidth, so then how my NVMe hitting 7518MBytes/s = 7.341GBytes = 63.05Gbits ?
Arwen
As for your odd NVMe speed numbers, are you using ZFS dataset compression?
That is one of the side effects of ZFS dataset compression, added read speed. The drive can act faster than it really is, because the amount of data it is sending is less than what is actually stored. Getting 2 to 1 compression, would give the appearance of a drive being twice as fast.
Now if you are not using ZFS dataset compression, (which is the default), I don't know.
MrGuvernment
Currently have compression off when the testing was done, this system just wants to keep me guessing it seems! Not that I don't enjoy the speeds being reported, but also wondering how and what may not be working as it should...
Arwen
The other thing with speed tests, the data being read could be in RAM because of ZFS ARC, (Adapter Replacement Cache).
It is almost required to flush ARC before each read test. And if the test performs multiple reads on the same data, flushing the ARC before the test may not help because the multiple reads re-populate it.
MrGuvernment
Could be, I was using the FIO switch for --direct=1 which is "supposed" to bypass buffered I/O... but then, I would presume if it was not using that switch and going from ARC instead, I would see far above the 7k MBytes/s speeds, potential double or more...
Time for a new round of testing perhaps, flushing the ZFS ARC and running things through again to see
I appreciate the help!
MrGuvernment
K, been busy with work, not done too much around this lately.
I did have one curiosity, CPU usage, while running several of the tests above, you can see that CPU usage spikes and in some instances, pegs a single thread to 100%.... this only seems to happen on READ tests, and happens across whether the PCIe runs through the CPU or the PCH....
CPU is decent, Intel Xeon Silver 4114 (10c/20t), but lower clocked at 2.2Ghz default...
This is running a single instance of of the below against my 4 x NVMe in a mirror config...so also seems I am limited to a single NVMe's read speeds?
fio --name TESTSeqRead --eta-newline=5s --filename=fio-tempfile-RSeq1.dat --rw=read --size=500m --io_size=250g --blocksize=1024k --fsync=10000 --iodepth=32 --direct=1 --numjobs=1 --runtime=260 --group_reporting
Arwen
Sorry, I don't know.
