Hello All,
New to the forum and TrueNas.
Great community hope u can help.
I have a used Dell Poweredge R330 with E-3 1280v5 16GB of RAM
PERC H730 Adapter in hba mode and 7 x 1TB sata 3.5inc "Entreprise" HDDs 7200rpm.
Now i know is better to start with new HDDs with larger capacity and leave room for SSDs instead.
Maxing on memory is also a must i understand.
But for now i just added a normal 1TB 7200 HDD.
Before i create a pool i wanted to bencmark my hdds to verify that all perform the same
Please see my results below.
I expected from the enterprise HDDs to perform at least the same with the new Desktop HDD?
What is wrong here?
Thanks for ur replies and Marry Christmass
Run status group 0 (all jobs):
root@truenas1[~]# fio --filename=/dev/da0 --direct=1 --fsync=1 --rw=randwrite --bs=4k --numjobs=1 --iodepth=1 --runtime=60 --time_based --group_reporting --name=4k-sync-write-test
4k-sync-write-test: (g=0): rw=randwrite, bs=(R) 4096B-4096B, (W) 4096B-4096B, (T) 4096B-4096B, ioengine=psync, iodepth=1
fio-3.27
WRITE: bw=309KiB/s (317kB/s), 309KiB/s-309KiB/s (317kB/s-317kB/s), io=18.1MiB (19.0MB), run=60002-60002msec
root@truenas1[~]#
root@truenas1[~]# dd if=/dev/zero of=/dev/da0 bs=2048k count=1k
1024+0 records in
1024+0 records out
2147483648 bytes transferred in 48.100330 secs (44645923 bytes/sec)
root@truenas1[~]#
Disk Type:
HDD
Description:
Model:
ATA TOSHIBA MG03ACA1
Transfer Mode:
Auto
Rotation Rate (RPM):
7200
HDD Standby:
ALWAYS ON
Adv. Power Management:
DISABLED
Acoustic Level:
DISABLED
Enable S.M.A.R.T.:
true
S.M.A.R.T. extra options:
root@truenas1[~]# fio --filename=/dev/da1 --direct=1 --fsync=1 --rw=randwrite --bs=4k --numjobs=1 --iodepth=1 --runtime=60 --time_based --group_reporting --name=4k-sync-write-test
fio-3.27
Jobs: 1 (f=1): [f(1)][100.0%][w=19KiB/s][w=4 IOPS][eta 00m:00s]
WRITE: bw=309KiB/s (316kB/s), 309KiB/s-309KiB/s (316kB/s-316kB/s), io=18.1MiB (19.0MB), run=60001-60001msec
root@truenas1[~]#
root@truenas1[~]# dd if=/dev/zero of=/dev/da1 bs=2048k count=1k
1024+0 records in
1024+0 records out
2147483648 bytes transferred in 47.914339 secs (44819227 bytes/sec)
root@truenas1[~]#
Disk Type:
HDD
Description:
Model:
Transfer Mode:
Auto
7200
HDD Standby:
ALWAYS ON
DISABLED
Acoustic Level:
DISABLED
Enable S.M.A.R.T.:
true
root@truenas1[~]# fio --filename=/dev/da2 --direct=1 --fsync=1 --rw=randwrite --bs=4k --numjobs=1 --iodepth=1 --runtime=60 --time_based --group_reporting --name=4k-sync-write-test
fio-3.27
WRITE: bw=310KiB/s (317kB/s), 310KiB/s-310KiB/s (317kB/s-317kB/s), io=18.1MiB (19.0MB), run=60001-60001msec
root@truenas1[~]#
root@truenas1[~]# dd if=/dev/zero of=/dev/da2 bs=2048k count=1k
1024+0 records in
1024+0 records out
2147483648 bytes transferred in 47.922465 secs (44811628 bytes/sec)
root@truenas1[~]#
Disk Type:
HDD
Description:
Model:
Transfer Mode:
Auto
7200
HDD Standby:
ALWAYS ON
DISABLED
Acoustic Level:
DISABLED
Enable S.M.A.R.T.:
true
root@truenas1[~]# fio --filename=/dev/da3 --direct=1 --fsync=1 --rw=randwrite --bs=4k --numjobs=1 --iodepth=1 --runtime=60 --time_based --group_reporting --name=4k-sync-write-test
fio-3.27
WRITE: bw=302KiB/s (309kB/s), 302KiB/s-302KiB/s (309kB/s-309kB/s), io=17.7MiB (18.5MB), run=60005-60005msec
root@truenas1[~]#
root@truenas1[~]# dd if=/dev/zero of=/dev/da3 bs=2048k count=1k
1024+0 records in
1024+0 records out
2147483648 bytes transferred in 28.763373 secs (74660354 bytes/sec)
root@truenas1[~]#
Disk Type:
HDD
Description:
Model:
ATA HUS722T1TALA600
Transfer Mode:
Auto
7200
HDD Standby:
ALWAYS ON
DISABLED
Acoustic Level:
DISABLED
Enable S.M.A.R.T.:
true
root@truenas1[~]# fio --filename=/dev/da4 --direct=1 --fsync=1 --rw=randwrite --bs=4k --numjobs=1 --iodepth=1 --runtime=60 --time_based --group_reporting --name=4k-sync-write-test
fio-3.27
WRITE: bw=301KiB/s (308kB/s), 301KiB/s-301KiB/s (308kB/s-308kB/s), io=17.6MiB (18.5MB), run=60007-60007msec
root@truenas1[~]#
root@truenas1[~]# dd if=/dev/zero of=/dev/da4 bs=2048k count=1k
1024+0 records in
1024+0 records out
2147483648 bytes transferred in 28.963225 secs (74145183 bytes/sec)
root@truenas1[~]#
Disk Type:
HDD
Description:
Model:
ATA HUS722T1TALA600
Transfer Mode:
Auto
7200
HDD Standby:
ALWAYS ON
DISABLED
Acoustic Level:
DISABLED
Enable S.M.A.R.T.:
true
root@truenas1[~]# fio --filename=/dev/da5 --direct=1 --fsync=1 --rw=randwrite --bs=4k --numjobs=1 --iodepth=1 --runtime=60 --time_based --group_reporting --name=4k-sync-write-test
fio-3.27
WRITE: bw=303KiB/s (310kB/s), 303KiB/s-303KiB/s (310kB/s-310kB/s), io=17.8MiB (18.6MB), run=60001-60001msec
root@truenas1[~]#
root@truenas1[~]# dd if=/dev/zero of=/dev/da5 bs=2048k count=1k
1024+0 records in
1024+0 records out
2147483648 bytes transferred in 28.846676 secs (74444753 bytes/sec)
root@truenas1[~]#
Disk Type:
HDD
Description:
Model:
ATA HUS722T1TALA600
Transfer Mode:
Auto
7200
HDD Standby:
ALWAYS ON
DISABLED
Acoustic Level:
DISABLED
Enable S.M.A.R.T.:
true
root@truenas1[~]# fio --filename=/dev/da6 --direct=1 --fsync=1 --rw=randwrite --bs=4k --numjobs=1 --iodepth=1 --runtime=60 --time_based --group_reporting --name=4k-sync-write-test
fio-3.27
WRITE: bw=300KiB/s (307kB/s), 300KiB/s-300KiB/s (307kB/s-307kB/s), io=17.6MiB (18.4MB), run=60001-60001msec
root@truenas1[~]#
root@truenas1[~]# dd if=/dev/zero of=/dev/da6 bs=2048k count=1k
1024+0 records in
1024+0 records out
2147483648 bytes transferred in 28.881136 secs (74355927 bytes/sec)
root@truenas1[~]#
Disk Type:
HDD
Description:
Model:
ATA HUS722T1TALA600
Transfer Mode:
Auto
7200
HDD Standby:
ALWAYS ON
DISABLED
Acoustic Level:
DISABLED
Enable S.M.A.R.T.:
true
root@truenas1[~]# fio --filename=/dev/da7 --direct=1 --fsync=1 --rw=randwrite --bs=4k --numjobs=1 --iodepth=1 --runtime=60 --time_based --group_reporting --name=4k-sync-write-test
fio-3.27
WRITE: bw=606KiB/s (621kB/s), 606KiB/s-606KiB/s (621kB/s-621kB/s), io=35.5MiB (37.2MB), run=60005-60005msec
root@truenas1[~]#
root@truenas1[~]# dd if=/dev/zero of=/dev/da7 bs=2048k count=1k
1024+0 records in
1024+0 records out
2147483648 bytes transferred in 11.755133 secs (182684762 bytes/sec)
root@truenas1[~]#
Disk Type:
HDD
Description:
Model:
ATA ST1000DM010-2EP1
Transfer Mode:
Auto
7200
HDD Standby:
ALWAYS ON
DISABLED
Acoustic Level:
DISABLED
Enable S.M.A.R.T.:
true
What is wrong here?
fio-3.27
root@truenas1[~]#
1024+0 records in
1024+0 records out
root@truenas1[~]#
Disk Type:
HDD
Description:
Model:
Transfer Mode:
Auto
7200
HDD Standby:
ALWAYS ON
DISABLED
Acoustic Level:
DISABLED
Enable S.M.A.R.T.:
true
fio-3.27
root@truenas1[~]#
1024+0 records in
1024+0 records out
root@truenas1[~]#
Disk Type:
HDD
Description:
Model:
Transfer Mode:
Auto
7200
HDD Standby:
ALWAYS ON
DISABLED
Acoustic Level:
DISABLED
Enable S.M.A.R.T.:
true
fio-3.27
root@truenas1[~]#
1024+0 records in
1024+0 records out
root@truenas1[~]#
Disk Type:
HDD
Description:
Model:
Transfer Mode:
Auto
7200
HDD Standby:
ALWAYS ON
DISABLED
Acoustic Level:
DISABLED
Enable S.M.A.R.T.:
true
fio-3.27
root@truenas1[~]#
1024+0 records in
1024+0 records out
root@truenas1[~]#
Disk Type:
HDD
Description:
Model:
ATA HUS722T1TALA600
Transfer Mode:
Auto
7200
HDD Standby:
ALWAYS ON
DISABLED
Acoustic Level:
DISABLED
Enable S.M.A.R.T.:
true
fio-3.27
root@truenas1[~]#
1024+0 records in
1024+0 records out
root@truenas1[~]#
Disk Type:
HDD
Description:
Model:
ATA HUS722T1TALA600
Transfer Mode:
Auto
7200
HDD Standby:
ALWAYS ON
DISABLED
Acoustic Level:
DISABLED
Enable S.M.A.R.T.:
true
fio-3.27
root@truenas1[~]#
1024+0 records in
1024+0 records out
root@truenas1[~]#
Disk Type:
HDD
Description:
Model:
ATA HUS722T1TALA600
Transfer Mode:
Auto
7200
HDD Standby:
ALWAYS ON
DISABLED
Acoustic Level:
DISABLED
Enable S.M.A.R.T.:
true
fio-3.27
root@truenas1[~]#
1024+0 records in
1024+0 records out
root@truenas1[~]#
Disk Type:
HDD
Description:
Model:
ATA HUS722T1TALA600
Transfer Mode:
Auto
7200
HDD Standby:
ALWAYS ON
DISABLED
Acoustic Level:
DISABLED
Enable S.M.A.R.T.:
true
fio-3.27
root@truenas1[~]#
1024+0 records in
1024+0 records out
root@truenas1[~]#
Disk Type:
HDD
Description:
Model:
Transfer Mode:
Auto
7200
HDD Standby:
ALWAYS ON
DISABLED
Acoustic Level:
DISABLED
Enable S.M.A.R.T.:
true
