Trunnas scale executables were found after upgrading to 22.02 yesterday
tongt15
Hi everyone,
I have experienced an unexpected error after upgarding to official release, however, I have reboot many times, and I have no idea why this error occured, please let me know if I am allowed to remove the apache2 file so that the alert will not show again... It's quite annoying
You could start with ls -l /usr/sbin/apache2 and then mv /usr/sbin/apache2 /tank/dataset (of course substituting a location on your own pool)
That way, you can put it back later if something is a problem... seems the file being there is the problem though, so I expect no issue.
Then you can remove the cores as instructed and the messages should stop.
anodos
Sambassador
That error message means that apache (webdav) crashed. There have been some stability issues I've seen with recent apache releases. There should be core files (ending with .zst) in the path specified. Upload to our jira instance and we will investigate and see what needs to be fixed.
tongt15
Thank you guys, after terminating the webdav services, everthing back to normal, seems apache has some stability issues..
