Truneas Scale Crashing
Invert
Hi Truenas Forums!
I hope I'm in the right place but I'm officially out of ideas and I'm looking for help :)
I'm running truenas Scale on a Q1900-itx with an Intel J1900 CPU and 8GB RAM. For Storage I have 4 WD Green 1TB SSDs in a raidz1 configuration.
I tried both using an extra internal 60GB SSD with a SATA-PCIE card and an MSATA SSD in a USB Casing for the boot medium.
The crash happens very intermittently when I keep it running for a while. I basically only have nextcloud running (I tried the official one as well das the truecharts one). I already swapped the power supply. The 4 SSDs are hanging on on one molex to 4x SATA port, but I ran CPU and Disk benchmarks for a good while to see if any current spikes would trigger the crash. They didnt :)
I attached a small HDMI Display to see better whats going on, I attached some images from it here. On crash, the system becomes completely with the only "activity" being the Ethernet LEDs still blinking.
Any ideas where I can start looking? The system was running fine with openmediavault (albeit without the 4 SSDs, I had a single HDD attached instead).
