itet
- Aug 19, 2020
I have 5 TrueNAS Scale 23.10.1.3 devices and on 3 of them the scrub will run in boot loop since 4 months.
TrueNAS01 proxmox virtual machine (1 socket, 8 cores, 36 GiB) with 1x virtual HD for boot, 1x virtual HD for apps, 1x pcie path through with 10 HD for data
TrueNAS02 proxmox virtual machine (1 socket, 8 cores, 12 GiB) with 1x virtual HD for boot, 1x virtual HD for apps, 1x virtual HD for data
TrueNAS11 proxmox virtual machine (1 socket, 8 cores, 36 GiB) with 1x virtual HD for boot, 1x virtual HD for apps, 1x pcie path thorugh with 5HD for data
TrueNAS21 proxmox 10SDV-4C-TLN2F Supermicro 16GiB, boot on usb msata 32GB SSD, 5HD for Data
TrueNAS22 proxmox 10SDV-4C-TLN2F Supermicro 16GiB, boot on usb msata 32GB SSD, 5HD for Data
On TrueNAS 01, 11 and 21 I have on a sub dataset which I use for UrBackup activated deduplication. I'm not sure but it feels the boot loop when running scrub has something todo with deduplication. I'm not sure because scrub running ones a month and also some truenas updates are placed at this time. First I paused the scrub and wait until next truenas updates but same situation with 23.10.1.3. When pause the scrub all 3 systems running without any problems.
Logs are very difficult because crash showing no failure at logs.
On these three machine with boot loop happen on different percent of scrub TrueNAS01 at 51%, TrueNAS11 at 54% and TrueNAS21 at 80%.
to underline the combination of scrub and dedup what is the best way to deactivate the dedup and bring on one system the data to a undedup state to try then the scrub again?
