CDuv
 - Aug 11, 2014
TL;DR: Can I have a TrueNAS SCALE server N1 sharing data over iSCSI with a Proxmox server P1 hosting a TrueNAS SCALE server N2 consuming said iSCSI drive?
I have the following two working servers:
Note: I am using a dedicated LAN (separate Ethernet NICs) between N1 and P1 for the iSCSI trafic: let's call it a "SAN".
Other thought: I initially thought N2 could access iSCSI share from N1 directly (avoiding any configuration on Proxmox) but it looks like TrueNAS is not meant to have it's data on a remote server (oops?).
Is there a network protocol other than iSCSI that would be a better fit for this project?
NB: This is thread was also started on Proxmox's community forum.
- N1: a TrueNAS SCALE (v23.10.0.1) server with nine 2TB HDD (in RAIDZ2 setup) and 64 GB of RAM
 - P1: a Proxmox (v7.4) server with eight 1TB HDD (in RAIDZ2 setup) and 64 GB of RAM : it's part of a 4-nodes cluster but other nodes are lighter/smaller
- Create a Zvol "N2-data-zvol" on N1
 - Share this Zvol over iSCSI
 - Declare a new iSCSI storage on P1 that accesses this iSCSI share from N1
 - Create a VM for N2 with 2 virtual disks: one local (for system) and another that uses the declared iSCSI storage (for data)
 - Install TrueNAS SCALE on the VM
- All my data are on one server (N1: that I must backup of course)
 - N2 is virtualized:
- easier state/configuration backup
 - I can scale up or down CPU and RAM
 - I can move N2 over my cluster when I need to perform maintenance on physical servers (cluster nodes)
- The setup requires 2 physical servers and a VM to be up (N1, P1 and N2) and working network between them
