Truenas Scale zpool offline after reboot
sarieri
Does anyone know why zpool randomly goes offline after reboot? Never had any of this problem in Truenas Core. I can import using Cli without any problem when this problem happens. But it will happen randomly after each reboot. I did multiple clean export in GUI so that should not be the problem
sarieri
It pops this up in GUI everytime zpools go offline.
Failed to configure kubernetes cluster for Applications: Missing "Micron/ix-applications/k3s, Micron/ix-applications/releases, Micron/ix-applications/docker" dataset(s) required for starting kubernetes.
2022-08-30 16:55:18 (America/New_York)
Samuel Tai
How are you rebooting? Via the UI, or directly from SSH via shutdown -r now? The correct way to reboot via SSH is midclt call system.reboot -job.
sarieri
I reboot in GUI.
Samuel Tai
Details of your hardware and pool(s), please, per the Forum Rules.
sarieri
Samuel Tai
Is your Micron pool attached to either of your HBAs or to your motherboard SATA ports? This sounds like a timing issue.
sarieri
Just checked it. All 5 Microns and the boot-pool drive are attached to onboard sata controller. 11 WDC drives are attached to HBA card and all 5 HGST drives are attached to HBA cards. There is one last WDC drive connected to onboard sata controller as well since there are only 16 ports available on two HBA cards.
sarieri
I figured that this has something to do with truecharts. After remove truecharts from catalog. This problem seems no longer exist, but that contradicts to the point of migrating to truenas scale, so I guess I will just roll back to core.
