TrueNAS SCALE - Using Safari for noVNC 'display' kills Safari instance after a while :(
tackyone
I'm using macOS Monterey to admin my TrueNAS SCALE box - and I've noticed bringing up a 'display' for virtual machines has two issues.
The first isn't too much of a biggy - but it triggers the popup-protector in Safari, so that if you don't know what you're looking for - you think it hasn't worked.
Secondly - which is much more annoying is, if you leave a noVNC console around for more than about thirty seconds - that instance of Safari starts getting sluggish. Then (if you're lucky) you start getting warnings that the page is using excessive energy - and it pegs a CPU core, and causes the system to "pinwheel" - and that tab to effectively crash (it gets to the point where you can't close it, nor even move the safari window around).
Anyone else seeing similar?
Thanks!
