Installing Jenkins on TrueNAS Scale and using docker to build/push images
wojg21
I have Jenkins installed in the APPS section of TrueNAS Scale. It is up and running, I have it setup but I am unable to build/push docker images because I am getting this error:
Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
I would probably need to use the Hosts docker instance but I am NOT familiar with how to configure that using the TrueNAS Scale installation wizard or possibly run a command on the instance, but also so it persists if I restart the APP. Any feedback, suggestion, is greatly appreciated! Thank you!!!
