wbr2000
- Jan 11, 2022
I run Jenkins in a docker container on TrueNAS-SCALE-22.02.2.1. I can access the Jenkins webserver from other computers in the network with the URL hostx:9080. But I fail to access the Jenkins Webserver, when I try to connect through an SSH tunnel hosted hostx. Running the command "netstat -tln" on hostx does not show any of the exposed ports of the docker image. Port 80, 443 etc are listed and port 80 can be used through the ssh tunnel.
I had no issue to access via ssh tunnel when I was using TrueNAS Core with a vm and jenkins running in the vm.
