SOLVED TrueNAS Scale(upgrade) - 22.02-RC.1-2 - SMB Share inactive
Cowagz
I have just upgraded from Truenas Core to Scale;
Restoring the backup(core) and uploading it to scale was not an issue, i can confirm network settings, and Storage Pool(1) came back as they previously configured in core.
Issue - i am unable to log in to my network storage(NAS via SMB share protocol - can confirm it did work on my old core setup) via the run command window(ip address of nas), or the windows explorer(under network).
i have made a new user 'amzahc' in an attempt to solve this problem when i moved across to Scale. However, even after creating this new user & retaining the old user accounts from the Core setup i am still at a loss> Substantiation of setup below.
IMG 1 shows the storage Online, 6 drives no errors.
IMG 2 shows storage tab> pool online> - with dataset permissions for user amzahc - (as far as i can tell, all permissions are set; therefore the user should have carte blanche)
IMG 3 shows sharing tab>Windows SMB Share>Edit Filesystem ACL> (can confirm amzahc has "allow |full control)
IMG 4 shows Credentials Tab>Local users>amzahc>(read write & Execute home directory permissions - not shown in IMG but can confirm Samba Authentication is
active)
IMG 5 shows Credentials Tab>Local Groups>amzahc (user group amzahc. Samba authentication : true)
IMG 6 > run command on windows 10> Direct IP Addy of NAS > ' you do not have permission to access........"
IMG 7 > Attempt to map network Drive > sign in using different credentials(both amzahc & root)> 'network folder specifed is currently mapped using different username and password. > Can confirm there arnt any other drives mapped.
Can you please advise if i am missing something,
Thanks in advance.
Cowagz
Update - Remedy;
Further tinkering has resolved the error.
IMG 1 Within Windows, - Start>credential Manager>Windows Credentials>Add Windows Credential>NAS Address Username & Password
IMG 2 Within Windows -
Cowagz
IMG 2 - Within Windows>Windows Features> SMB 1.0 and SMB Direct> Install.
For Anyone who is experiencing errors when migrating from Core to Scale(SMB Sharing); the above fix has resolved my particular error.
