Good morning,
I am in the process of reinstalling my server which was used for data storage, backups and data sharing via Nextcloud. Previously it was based on proxmox and nextcloud was a container. I used HAproxy on pfsens as a reverse-proxy.
It will now be based on the Truenas Scale. I will use 'Traefic' as a reverse-proxy.
I have two questions/problems:
1. I tried to arrange the disks as common sense as possible, but I would be grateful for suggestions on my pool placement, should I modify something or can it stay that way?
2. I'm stuck where I'm not sure where to put the 'ix-applications' dataset
Pool1 from SSDs is intended to be fast to make applications and vms run fast. But if I put the 'ix-applications' dataset there, will I be able to tell Nexcloud to store the data-heavy dataset in Pool0?
I will be grateful for suggestions.
Regards!
ztSystem Congaree12 Chassis 24x3.5 bay
2 x Xeon(R) CPU E5-2620 0 @ 2.00GHz
102.3GiB DDR3 ECC
2 x Intel Corporation 82599ES 10-Gigabit SFI/SFP+ bond(load balance)
3 x LSI SAS2008-IT
boot-pool
2 x 120 GB CT120BX500SSD1 (Mirror)
Tank0 - (general data storage, SMB, iSCSI, Nextcloud Data?, Apps? )
8 x 6TB Seagate IronWolf SATA 6 Gb/s (ST6000VN001) (Tank0 - Data VDEV - RAIDZ2 - Usable Capacity:30.9 TiB)
2 x 275 GB SSD CT275MX300SSD1 (Cache VDEVs)
2 x 275 GB SSD CT275MX300SSD1 (Log VDEVs - mirror)
Tank1 - (VM, Apps? )
4 x 512 GB SSD CT500MX500SSD1 (Tank1 - Data VDEV - strip of mirrors - Usable Capacity:891.5 GiB)
102.3GiB DDR3 ECC
3 x LSI SAS2008-IT
boot-pool
Regards!
