Quota exceeded on dataset Tank/ix-applications/default_volumes/pvc-fa23a61c-94fa-4eff-8954-cc8ab3827e5c. Used 96.41% (963.14 GiB of 999 GiB).
NugentS
Just installed the latest nightly for Scale and I get the Critical Errors
This I find interesting on the following grounds.
1. There are no quotas set
2. Tank - the main pool / the only pool is currently 2 mirrored virtual disks of 50GB each giving me 50GB of storage. I am unsure of where the other 950GB is coming from for me to use 963.14GiB of 999GiB
I do have a container ix-applications which uses 3.58GB but the folder mentioned does not seem to exist
Actually got three errors:
Quota exceeded on dataset Tank/ix-applications/releases/nextcloud/volumes/pvc-53bc4195-f13e-4016-bf0d-939104a552be. Used 96.41% (963.14 GiB of 999 GiB).
Quota exceeded on dataset Tank/ix-applications/releases/nextcloud/volumes/pvc-f68012ff-fe59-4ef7-aac5-55bbaf0ca5f5. Used 96.41% (963.14 GiB of 999 GiB).
I do have a nextcloud container - but it has no data and actually does nothing
Tank is 22% Used
TrueNAS-SCALE-21.09-MASTER-20210914-052922. Running on VMWare for feature testing purposes
NugentS
Gone on TrueNAS-SCALE-21.09-MASTER-20210914-072920
NugentS
And now re-appeared TrueNAS-SCALE-21.09-MASTER-20210914-092923
morganL
Captain Morgan
Administrator
Can you confirm they are not in SCALE 21.08 ?
NugentS
Only appeared on a recent daily update.
They are not in the current Beta
I can log on Jira as a bug - but I was curious if anyone else had seen this
squachen
I get this same error on SCALE 21.08 when trying to install authelia from truecharts. I'm using all default values, only supplying my domain/url info to the setup wizard. This is the only app I've tried where this happens. Other apps seem to work fine. (mostly tried the *arr apps and traefik)
Quota exceeded on dataset zpool1/ix-applications/default_volumes/pvc-944629f2-0359-4b84-a8b3-5528462f84aa. Used 92.11% (920.15 GiB of 999 GiB).
Quota exceeded on dataset zpool1/ix-applications/releases/authelia/volumes/pvc-03e0e813-f1e4-4846-8d8d-09fb2625990b. Used 92.11% (920.15 GiB of 999 GiB).
Quota exceeded on dataset zpool1/ix-applications/releases/authelia/volumes/pvc-2465a898-ecf7-40c7-ba13-c203c49a7362. Used 92.11% (920.15 GiB of 999 GiB).
NugentS
