jlento
- Aug 7, 2022
- TrueNAS: TrueNAS-12.0-U8.1
- Motherboard: X470D4U
- Processor: AMD Ryzen 5 3600
- Memory: 4xKingston 16GB ECC 9965745-002.A00G
- Disks (Pool):
- 6xHGST HUS726040ALA614
- 1xHGST HUS726040ALE610
- 1xWDC WD40EFZX-68AWUN0
- Disks (OS):
- 2xGIGABYTE GP-GSM2NE8128GNTD (RAID1)
- Network: 8086 Intel
Been running pretty solid for the better part of 1.5 years but late last week when I was on travel, I got an alert saying that /dev/ada2 was having issues and that my pool was degraded. Essentially that the error count when from 0 to 1 and there were unreadable sectors. No big deal as I've had drive issues in the past so I took out a new one (another HGST at the time), Offlined the drive, swapped in the new one, and went to Replace and let resilvering commence. This is when the issues began.
About 20% into resilvering my machine just rebooted. Ended up with some more email alerts essentially saying the same thing, /dev/ada2 error count increased from 0 to 20, unreadable sectors, and there were 10 uncorrectable sectors. I thought this was odd but assumed I had another bad drive so I ran to Best Buy and grabbed the only WD Red drive they had and restarted the process. Again, the same thing, reboots everytime I unlock my pool (encrypted) and start resilvering.
I tried searching through the forums, I disabled my Jails and VM's from start at boot, removed power, etc however every time I unlock my pool and the resilvering process starts my machine will reboot within 30 minutes. I can't really figure out what the issue is as I don't have good logs, just my email alerts when it goes down and comes back up.
Any guidance would be appreciated.
Current alerts: * Device: /dev/ada2, ATA error count increased from 0 to 20. * Device: /dev/ada2, 1 Currently unreadable (pending) sectors. * Device: /dev/ada2, Self-Test Log error count increased from 0 to 1. * Device: /dev/ada2, 10 Offline uncorrectable sectors. * johnnycache.local had an unscheduled system reboot. The operating system successfully came back online at Sun Aug 7 15:41:50 2022. * johnnycache.local had an unscheduled system reboot. The operating system successfully came back online at Sun Aug 7 16:58:33 2022. * johnnycache.local had an unscheduled system reboot. The operating system successfully came back online at Sun Aug 7 20:09:57 2022. * johnnycache.local had an unscheduled system reboot. The operating system successfully came back online at Sun Aug 7 21:00:23 2022.
root@truenas[~]# smartctl -x /dev/ada2 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p14 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: WDC WD40EFZX-68AWUN0 Serial Number: WD-WX52DC19UC1C LU WWN Device Id: 5 0014ee 2bfb05bfa Firmware Version: 81.00B81 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Aug 7 21:03:36 2022 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is: Unavailable APM feature is: Unavailable Rd look-ahead is: Enabled Write cache is: Enabled DSN feature is: Unavailable ATA Security is: Disabled, frozen [SEC2] Wt Cache Reorder: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (41520) seconds. Offline data collection capabilities: (0x11) SMART execute Offline immediate. No Auto Offline data collection support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. No Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 442) minutes. SCT capabilities: (0x303d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate POSR-K 100 253 051 - 0 3 Spin_Up_Time POS--K 100 253 021 - 0 4 Start_Stop_Count -O--CK 100 100 000 - 2 5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0 7 Seek_Error_Rate -OSR-K 100 253 000 - 0 9 Power_On_Hours -O--CK 100 100 000 - 1 10 Spin_Retry_Count -O--CK 100 253 000 - 0 11 Calibration_Retry_Count -O--CK 100 253 000 - 0 12 Power_Cycle_Count -O--CK 100 100 000 - 2 192 Power-Off_Retract_Count -O--CK 200 200 000 - 0 193 Load_Cycle_Count -O--CK 200 200 000 - 2 194 Temperature_Celsius -O---K 116 115 000 - 34 196 Reallocated_Event_Count -O--CK 200 200 000 - 0 197 Current_Pending_Sector -O--CK 200 200 000 - 0 198 Offline_Uncorrectable ----CK 100 253 000 - 0 199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0 200 Multi_Zone_Error_Rate ---R-- 100 253 000 - 0 ||||||_ K auto-keep |||||__ C event count ||||___ R error rate |||____ S speed/performance ||_____ O updated online |______ P prefailure warning General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x02 SL R/O 5 Comprehensive SMART error log 0x03 GPL R/O 6 Ext. Comprehensive SMART error log 0x04 GPL,SL R/O 8 Device Statistics log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 1 Extended self-test log 0x09 SL R/W 1 Selective self-test log 0x10 GPL R/O 1 NCQ Command Error log 0x11 GPL R/O 1 SATA Phy Event Counters log 0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log 0x80-0x9f GPL,SL R/W 16 Host vendor specific log 0xa0-0xa7 GPL,SL VS 16 Device vendor specific log 0xa8-0xb6 GPL,SL VS 1 Device vendor specific log 0xb7 GPL,SL VS 78 Device vendor specific log 0xbd GPL,SL VS 1 Device vendor specific log 0xc0 GPL,SL VS 1 Device vendor specific log 0xc1 GPL VS 93 Device vendor specific log 0xe0 GPL,SL R/W 1 SCT Command/Status 0xe1 GPL,SL R/W 1 SCT Data Transfer SMART Extended Comprehensive Error Log Version: 1 (6 sectors) No Errors Logged SMART Extended Self-test Log Version: 1 (1 sectors) No self-tests have been logged. [To run self-tests, use: smartctl -t] Selective Self-tests/Logging not supported SCT Status Version: 3 SCT Version (vendor specific): 258 (0x0102) Device State: Active (0) Current Temperature: 34 Celsius Power Cycle Min/Max Temperature: 33/34 Celsius Lifetime Min/Max Temperature: 24/34 Celsius Under/Over Temperature Limit Count: 0/0 Vendor specific: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 SCT Temperature History Version: 2 Temperature Sampling Period: 1 minute Temperature Logging Interval: 1 minute Min/Max recommended Temperature: 0/65 Celsius Min/Max Temperature Limit: -41/85 Celsius Temperature History Size (Index): 478 (100) Index Estimated Time Temperature Celsius 101 2022-08-07 13:06 ? - ... ..(376 skipped). .. - 0 2022-08-07 19:23 ? - 1 2022-08-07 19:24 24 ***** 2 2022-08-07 19:25 25 ****** 3 2022-08-07 19:26 26 ******* 4 2022-08-07 19:27 27 ******** 5 2022-08-07 19:28 28 ********* 6 2022-08-07 19:29 28 ********* 7 2022-08-07 19:30 29 ********** 8 2022-08-07 19:31 29 ********** 9 2022-08-07 19:32 30 *********** 10 2022-08-07 19:33 30 *********** 11 2022-08-07 19:34 31 ************ 12 2022-08-07 19:35 31 ************ 13 2022-08-07 19:36 32 ************* ... ..( 2 skipped). .. ************* 16 2022-08-07 19:39 32 ************* 17 2022-08-07 19:40 33 ************** ... ..( 23 skipped). .. ************** 41 2022-08-07 20:04 33 ************** 42 2022-08-07 20:05 34 *************** ... ..( 15 skipped). .. *************** 58 2022-08-07 20:21 34 *************** 59 2022-08-07 20:22 ? - 60 2022-08-07 20:23 34 *************** 61 2022-08-07 20:24 33 ************** ... ..( 23 skipped). .. ************** 85 2022-08-07 20:48 33 ************** 86 2022-08-07 20:49 34 *************** ... ..( 13 skipped). .. *************** 100 2022-08-07 21:03 34 *************** SCT Error Recovery Control: Read: 70 (7.0 seconds) Write: 70 (7.0 seconds) Device Statistics (GP Log 0x04) Page Offset Size Value Flags Description 0x01 ===== = = === == General Statistics (rev 1) == 0x01 0x008 4 2 --- Lifetime Power-On Resets 0x01 0x010 4 1 --- Power-on Hours 0x01 0x018 6 470225610 --- Logical Sectors Written 0x01 0x020 6 1505680 --- Number of Write Commands 0x01 0x028 6 128095 --- Logical Sectors Read 0x01 0x030 6 1650 --- Number of Read Commands 0x01 0x038 6 3600000 --- Date and Time TimeStamp 0x03 ===== = = === == Rotating Media Statistics (rev 1) == 0x03 0x008 4 1 --- Spindle Motor Power-on Hours 0x03 0x010 4 1 --- Head Flying Hours 0x03 0x018 4 2 --- Head Load Events 0x03 0x020 4 0 --- Number of Reallocated Logical Sectors 0x03 0x028 4 0 --- Read Recovery Attempts 0x03 0x030 4 0 --- Number of Mechanical Start Failures 0x03 0x038 4 0 --- Number of Realloc. Candidate Logical Sectors 0x03 0x040 4 0 --- Number of High Priority Unload Events 0x04 ===== = = === == General Errors Statistics (rev 1) == 0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors 0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion 0x05 ===== = = === == Temperature Statistics (rev 1) == 0x05 0x008 1 34 --- Current Temperature 0x05 0x010 1 - --- Average Short Term Temperature 0x05 0x018 1 - --- Average Long Term Temperature 0x05 0x020 1 34 --- Highest Temperature 0x05 0x028 1 31 --- Lowest Temperature 0x05 0x030 1 - --- Highest Average Short Term Temperature 0x05 0x038 1 - --- Lowest Average Short Term Temperature 0x05 0x040 1 - --- Highest Average Long Term Temperature 0x05 0x048 1 - --- Lowest Average Long Term Temperature 0x05 0x050 4 0 --- Time in Over-Temperature 0x05 0x058 1 65 --- Specified Maximum Operating Temperature 0x05 0x060 4 0 --- Time in Under-Temperature 0x05 0x068 1 0 --- Specified Minimum Operating Temperature 0x06 ===== = = === == Transport Statistics (rev 1) == 0x06 0x008 4 18 --- Number of Hardware Resets 0x06 0x010 4 15 --- Number of ASR Events 0x06 0x018 4 0 --- Number of Interface CRC Errors |||_ C monitored condition met ||__ D supports DSN |___ N normalized value Pending Defects log (GP Log 0x0c) not supported SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x0001 2 0 Command failed due to ICRC error 0x0002 2 0 R_ERR response for data FIS 0x0003 2 0 R_ERR response for device-to-host data FIS 0x0004 2 0 R_ERR response for host-to-device data FIS 0x0005 2 0 R_ERR response for non-data FIS 0x0006 2 0 R_ERR response for device-to-host non-data FIS 0x0007 2 0 R_ERR response for host-to-device non-data FIS 0x0008 2 0 Device-to-host non-data FIS retries 0x0009 2 7 Transition from drive PhyRdy to drive PhyNRdy 0x000a 2 9 Device-to-host register FISes sent due to a COMRESET 0x000b 2 0 CRC errors within host-to-device FIS 0x000d 2 0 Non-CRC errors within host-to-device FIS 0x000f 2 0 R_ERR response for host-to-device data FIS, CRC 0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC 0x8000 4 2542 Vendor specific
