TrueNAS not seeing disks (HBA)
jamerrr
Hi, I'm brand new to TrueNAS and I'm having trouble where it's not showing my disks in the disk shelf with a HBA pci passthrough card.
I've read through various posts in here about other users having the same issue and I've tried a few things but I still can't seem to get it working. Any help would be appreciated.
Here's the details of the setup
Server: HP dl380p Gen8
Shelf: EMC KTN-STL3 VNX DAE 15*3.5"
PCI-E: Dell 6GB/s PCIE 4 port Quad SAS HBA I/O
TrueNAS installed in a VM on ESXi
- (0000:0b:00.0) Avago (LSI Logic) Avago (LSI) Logic Fusion-MPT 6GSAS SAS2308_2 PCI-Express - Passthrough
- (0000:09:00.0) Avago (LSI Logic) Avago (LSI) Logic Fusion-MPT 6GSAS SAS2308_2 PCI-Express - Passthrough
TrueNAS VM - both PCI devices have been added
sas2flash -list
LSI Corporation SAS2 Flash Utility
Version 16.00.00.00 (2013.03.01)
Copyright (c) 2008-2013 LSI Corporation. All rights reserved
        Adapter Selected is a LSI SAS: SAS2308_2(D1)
        Controller Number              : 0
        Controller                     : SAS2308_2(D1)
        PCI Address                    : 00:13:00:00
        SAS Address                    : 5000d31-0-0046-df4f
        NVDATA Version (Default)       : 11.00.00.08
        NVDATA Version (Persistent)    : 11.00.00.08
        Firmware Product ID            : 0x2214 (IT)
        Firmware Version               : 17.85.00.00
        NVDATA Vendor                  : LSI
        NVDATA Product ID              : SAS9206-16e
        BIOS Version                   : N/A
        UEFI BSD Version               : N/A
        FCODE Version                  : N/A
        Board Name                     : SAS9206-16E
        Board Assembly                 : H3-25553-00D
        Board Tracer Number            : SV33119931
        Finished Processing Commands Successfully.
        Exiting SAS2Flash.
geom disk list
Geom name: da0
Providers:
1. Name: da0
   Mediasize: 17179869184 (16G)
   Sectorsize: 512
   Mode: r1w1e2
   descr: VMware Virtual disk
   ident: (null)
   rotationrate: 0
   fwsectors: 63
   fwheads: 255
Geom name: cd0
Providers:
1. Name: cd0
   Mediasize: 1047345152 (999M)
   Sectorsize: 2048
sas2ircu 0 display
LSI Corporation SAS2 IR Configuration Utility.
Version 20.00.00.00 (2014.09.18)
Copyright (c) 2008-2014 LSI Corporation. All rights reserved.
Read configuration has been initiated for controller 0
Controller information
  Controller type                         : SAS2308_2
  BIOS version                            : 0.00.00.00
  Firmware version                        : 17.85.00.00
  Channel description                     : 1 Serial Attached SCSI
  Initiator ID                            : 0
  Maximum physical devices                : 839
  Concurrent commands supported           : 12272
  Slot                                    : Unknown
  Segment                                 : 0
  Bus                                     : 19
  Device                                  : 0
  Function                                : 0
  RAID Support                            : No
IR Volume information
Physical device information
Initiator at ID #0
Device is a Hard disk
  Enclosure #                             : 1
  Slot #                                  : 0
  SAS Address                             : 5000d31-0-0046-df56
  State                                   : Available (AVL)
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Drive Type                              : SAS_HDD
  Enclosure #                             : 1
  Slot #                                  : 0
  SAS Address                             : 5000d31-0-0046-df50
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  SAS Address                             : 5000d31-0-0046-df51
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  SAS Address                             : 5000d31-0-0046-df52
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  SAS Address                             : 5000d31-0-0046-df53
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  SAS Address                             : 5000d31-0-0046-df54
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  SAS Address                             : 5000d31-0-0046-df55
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
Enclosure information
  Enclosure#                              : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
sas2ircu 1 display
Read configuration has been initiated for controller 1
  BIOS version                            : 7.39.02.00
  Firmware version                        : 20.00.07.00
  Initiator ID                            : 0
  Maximum physical devices                : 1023
  Concurrent commands supported           : 10240
  Slot                                    : Unknown
  Segment                                 : 0
  Bus                                     : 27
  Device                                  : 0
  Function                                : 0
  RAID Support                            : No
Initiator at ID #0
Device is a Enclosure services device
  Enclosure #                             : 2
  Slot #                                  : 117
  SAS Address                             : 5006048-0-0c58-4fbe
  State                                   : Standby (SBY)
  Manufacturer                            : EMC
  Model Number                            : ESES Enclosure
  Firmware Revision                       : 0001
  Serial No                               : PMCSIERA
  GUID                                    : N/A
  Protocol                                : SAS
  Device Type                             : Enclosure services device
jamerrr
forgot to copy/paste, but camcontrol command
camcontrol devlist
shows something like " EMC Enclosure ... "
jamerrr
Of course, thanks.
camcontrol devlist
camcontrol devlist
<NECVMWar VMware SATA CD00 1.00>   at scbus2 target 0 lun 0 (cd0,pass0)
<VMware Virtual disk 2.0>          at scbus32 target 0 lun 0 (pass1,da0)
<EMC ESES Enclosure 0001>          at scbus34 target 8 lun 0 (ses0,pass2)
OK, so I think your problem is that none of the disks are reporting back their serial numbers... what drives are they?
jamerrr
I have
- a bunch of Exos X16 10TB Enterprise
And i've also tried it with a WD Green 2TB and a WD Black 1TB drives alone
During the server boot, I found I was getting a red screen NMI error when trying to enter the Avagos SAS setup (ctrl-c).
I came across a blog post about HP DL380e (I have a DL380p) Gen 8 - regarding the SAS HBA controller firmware version 7.39.02 has this issue for the HPs. The solution was to downgrade to 7.39.00
NMI-Gen80 SAS HBA Blog Post
Note that the link to the HP site from that post didn't give me the proper version, but I found the proper 7.39.00 mtpsas2.rom here
Forum Post with Proper ROM file
I was able to sas2flash with the proper rom file from a TrueNAS shell. It didn't work initially, but realized that even tho there's 1 physical card, it shows as 2 PCI adapters
sas2flash -o -b mptsas2.rom
sas2flash -c 1 -o -b mptsas2.rom
After rebooting the server, it did show
Avago Technologies MPT SAS2 BIOS
MPT2BIOS-7.39.00.00 (2014.09.18)
and I was able to get into the Avagos Config Utility without the NMI Red Screen of Death.
It shows
AdapterPCI BusPCI DevPCI FncPCI SlotFW RevisionStatusBoot Order
SAS9206-16E090000FF20.00.07.00-ITEnabled0
SAS9206-16E0B0000FF17.85.00.00-ITEnabled1
At this point, I think it may be a hardware issue, anybody have any thoughts?
Thanks!
        NVDATA Vendor                  : LSI
        BIOS Version                   : N/A
        FCODE Version                  : N/A
        Exiting SAS2Flash.
sas2ircu 0 display
  Initiator ID                            : 0
  Slot                                    : Unknown
  Segment                                 : 0
  Bus                                     : 19
  Device                                  : 0
  Function                                : 0
  RAID Support                            : No
Initiator at ID #0
  Enclosure #                             : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure#                              : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
sas2ircu 1 display
  Initiator ID                            : 0
  Slot                                    : Unknown
  Segment                                 : 0
  Bus                                     : 27
  Device                                  : 0
  Function                                : 0
  RAID Support                            : No
Initiator at ID #0
  Enclosure #                             : 2
  Slot #                                  : 117
  Manufacturer                            : EMC
  GUID                                    : N/A
  Protocol                                : SAS
jamerrr
There's a mistake in the last post, I copied and pasted the wrong (older) outputs for sas2flash & sas2ircu. These show the proper BIOS version
sas2flash -list -c 0
        NVDATA Vendor                  : LSI
        BIOS Version                   : 07.39.00.00
        FCODE Version                  : N/A
        Exiting SAS2Flash.
sas2flash -list -c 1
        Controller Number              : 1
        PCI Address                    : 00:1b:00:00
        SAS Address                    : 500605b-0-06d9-8e60
        NVDATA Version (Default)       : 14.01.00.06
        NVDATA Version (Persistent)    : 14.01.00.06
        Firmware Version               : 20.00.07.00
        NVDATA Vendor                  : LSI
        FCODE Version                  : N/A
        Exiting SAS2Flash.
sas2ircu -0 display
Read configuration has been initiated for controller -0
  BIOS version                            : 7.39.00.00
  Initiator ID                            : 0
  Slot                                    : Unknown
  Segment                                 : 0
  Bus                                     : 19
  Device                                  : 0
  Function                                : 0
  RAID Support                            : No
Initiator at ID #0
  Enclosure #                             : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure #                             : 1
  Slot #                                  : 0
  Manufacturer                            :
  Model Number                            :
  Firmware Revision                       :
  Serial No                               :
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure#                              : 1
  Logical ID                              : 5000d310:0046df4f
  Numslots                                : 8
  StartSlot                               : 0
SAS2IRCU: Command DISPLAY Completed Successfully.
SAS2IRCU: Utility Completed Successfully.
 sas2ircu 1 display
  Initiator ID                            : 0
  Slot                                    : Unknown
  Segment                                 : 0
  Bus                                     : 27
  Device                                  : 0
  Function                                : 0
  RAID Support                            : No
Initiator at ID #0
  Enclosure #                             : 2
  Slot #                                  : 117
  Manufacturer                            : EMC
  GUID                                    : N/A
  Protocol                                : SAS
  Enclosure#                              : 1
  Logical ID                              : 500605b0:06d98e60
  Numslots                                : 8
  StartSlot                               : 0
  Enclosure#                              : 2
  Logical ID                              : 50060480:0c584fbe
  Numslots                                : 16
  StartSlot                               : 102
jamerrr
Figured it out, it was the EMC SATA Interposers that was the problem. Swapped with different interposers and now all the drives are visible.
Thanks!
Fleacox
Thanks!
I am running into this same issue with disks not getting detected. What is the part number of the interposers that worked for you?
