Don't see drive status LED after connecting it HP H220 HBA
hysel
I haven't reverted to back to the OEM firmware yet. I haven't been able to find the correct firmware/BIOS and flashing instructions for downgrading. I wasn't sure what your process was for when you did that previously.
Oh, I didn't downgrade, I just left it as it is
vampirebyte
We have the same "issue" with our build on HPE DL380 G9.
We also used the OEM H220 card and flashed it, all works great, all 8 SATA HPE Enterprise SSDs are visible and usable including SMART status, just the LEDs don't work anymore... what a pity.
It is actually detected and visible in HP iLO 4, it just needs AMS installed on the host to display also the drives.
Not sure how/if we can fix this without using the HP firmware :( I actually did not change the BIOS of the card, it's the original one afaik.
root@truenas[~]# sas2ircu 0 display
LSI Corporation SAS2 IR Configuration Utility.
Version 20.00.00.00 (2014.09.18)
Copyright (c) 2008-2014 LSI Corporation. All rights reserved.
Read configuration has been initiated for controller 0
Controller information
  Controller type                         : SAS2308_2
  BIOS version                            : 7.39.00.00
  Firmware version                        : 20.00.07.00
  Channel description                     : 1 Serial Attached SCSI
  Initiator ID                            : 0
  Maximum physical devices                : 1023
  Concurrent commands supported           : 10240
  Slot                                    : 3
  Segment                                 : 0
  Bus                                     : 8
  Device                                  : 0
  Function                                : 0
  RAID Support                            : No
IR Volume information
Physical device information
Initiator at ID #0
Device is a Hard disk
  Enclosure #                             : 1
  Slot #                                  : 0
  SAS Address                             : 4433221-1-0300-0000
  State                                   : Ready (RDY)
  Size (in MB)/(in sectors)               : 915715/1875385007
  Manufacturer                            : ATA
  Model Number                            : VK000960GWEZD
  Firmware Revision                       : HPGG
  Serial No                               : 17271964FD8C
  GUID                                    : 500a07511964fd8c
  Protocol                                : SATA
  Drive Type                              : SATA_SSD
  Enclosure #                             : 1
  Slot #                                  : 1
  SAS Address                             : 4433221-1-0200-0000
  State                                   : Ready (RDY)
  Manufacturer                            : ATA
  Serial No                               : 17271964FCF7
  GUID                                    : 500a07511964fcf7
  Protocol                                : SATA
  Enclosure #                             : 1
  Slot #                                  : 2
  SAS Address                             : 4433221-1-0100-0000
  State                                   : Ready (RDY)
  Manufacturer                            : ATA
  Serial No                               : 17271964FD2A
  GUID                                    : 500a07511964fd2a
  Protocol                                : SATA
  Enclosure #                             : 1
  Slot #                                  : 3
  SAS Address                             : 4433221-1-0000-0000
  State                                   : Ready (RDY)
  Manufacturer                            : ATA
  Serial No                               : 17271964FDAF
  GUID                                    : 500a07511964fdaf
  Protocol                                : SATA
  Enclosure #                             : 1
  Slot #                                  : 4
  SAS Address                             : 4433221-1-0700-0000
  State                                   : Ready (RDY)
  Manufacturer                            : ATA
  Serial No                               : 17271964FD01
  GUID                                    : 500a07511964fd01
  Protocol                                : SATA
  Enclosure #                             : 1
  Slot #                                  : 5
  SAS Address                             : 4433221-1-0600-0000
  State                                   : Ready (RDY)
  Manufacturer                            : ATA
  Serial No                               : 17271964FD9B
  GUID                                    : 500a07511964fd9b
  Protocol                                : SATA
  Enclosure #                             : 1
  Slot #                                  : 6
  SAS Address                             : 4433221-1-0500-0000
  State                                   : Ready (RDY)
  Manufacturer                            : ATA
  Serial No                               : 17271964FDEB
  GUID                                    : 500a07511964fdeb
  Protocol                                : SATA
  Enclosure #                             : 1
  Slot #                                  : 7
  SAS Address                             : 4433221-1-0400-0000
  State                                   : Ready (RDY)
  Manufacturer                            : ATA
  Serial No                               : 17271964FDFF
  GUID                                    : 500a07511964fdff
  Protocol                                : SATA
Enclosure information
  Enclosure#                              : 1
  Logical ID                              : 500605b0:08c416b0
  Numslots                                : 8
  StartSlot                               : 0
SAS2IRCU: Command DISPLAY Completed Successfully.
SAS2IRCU: Utility Completed Successfully.
root@truenas[~]#
