venezia
- Oct 7, 2022
Hi there
Recently I upgraded my mini X+ to 128GB of memory (replacing the original two RDIMMs for 2x64GB RDIMMS) - I did not try using the original RDIMMS together with the new memory as they technically did have a different speed and I did not want to have any compatibility issues. Having success at that, I decided to buy 6 more 64GB RDIMMs so I could fully upgrade my X+ and XL+ (I have one replicating the other, etc.)
The machines boot, get past the initial screen to select any boot options, however early into the normal boot they both hang at the same spot. I think I catch some sort of fault happening, but it goes by a bit too fast. I've tried 3 memory sticks (I know this isn't optimal, but to bring it to 192GB of memory) and get the same issue. 128GB loads just fine, but memory over this (or at least 192GB) seems to break the boot. Is there a compiled limit of how much memory is allowed?
I presume that since the bios seems happy (and I get the initial boot options screen, etc.) that the system is OK with the memory, but rather the OS seems to be having some hangups - but I could easily be wrong. The motherboard on these things is a Supermicro a2sdi-h-tf - which is what I used to check memory compatibility. It suggests 256GB is fair game.
I guess what I'm asking is this: has anyone tried to use Truenas 13 on these devices with memory over 128GB? Is there something I'm doing wrong? I suppose I do not need 128GB of memory, but it might be good to know what the limits are for others, etc.
Thanks!
Thanks!
