hi.
cores is empty, but in console.log i found this.
Mar 11 20:50:05 freenas Importing Pool-02
Mar 11 20:50:05 freenas spa.c:6138:spa_tryimport(): spa_tryimport: importing Pool-02
Mar 11 20:50:05 freenas spa_misc.c:411:spa_load_note(): spa_load($import, config trusted): LOADING
Mar 11 20:50:05 freenas spa.c:8187:spa_async_request(): spa=$import async request task=1
Mar 11 20:50:05 freenas vdev.c:129:vdev_dbgmsg(): disk vdev '/dev/gptid/a5ddfe79-6bdf-11eb-87cd-6805ca007b16': vdev_geom_open: failed to open [error=2]
Mar 11 20:50:05 freenas vdev.c:129:vdev_dbgmsg(): disk vdev '/dev/gptid/a5d07b77-6bdf-11eb-87cd-6805ca007b16': vdev_geom_open: failed to open [error=2]
Mar 11 20:50:05 freenas spa_misc.c:411:spa_load_note(): spa_load($import, config untrusted): vdev tree has 1 missing top-level vdevs.
Mar 11 20:50:05 freenas spa_misc.c:411:spa_load_note(): spa_load($import, config untrusted): current settings allow for maximum 0 missing top-level vdevs at this stage.
Mar 11 20:50:05 freenas spa_misc.c:396:spa_load_failed(): spa_load($import, config untrusted): FAILED: unable to open vdev tree [error=2]
Mar 11 20:50:05 freenas vdev.c:183:vdev_dbgmsg_print_tree(): vdev 0: root, guid: 14137448965918047143, path: N/A, can't open
Mar 11 20:50:05 freenas vdev.c:183:vdev_dbgmsg_print_tree(): vdev 0: raidz, guid: 17134527342197451087, path: N/A, can't open
Mar 11 20:50:05 freenas vdev.c:183:vdev_dbgmsg_print_tree(): vdev 0: disk, guid: 8464052132362910624, path: /dev/gptid/a579f19a-6bdf-11eb-87cd-6805ca007b16, healthy
Mar 11 20:50:05 freenas vdev.c:183:vdev_dbgmsg_print_tree(): vdev 1: disk, guid: 15547647455722688621, path: /dev/gptid/a586ee20-6bdf-11eb-87cd-6805ca007b16, healthy
Mar 11 20:50:05 freenas vdev.c:183:vdev_dbgmsg_print_tree(): vdev 2: disk, guid: 10692275990118619762, path: /dev/gptid/a5d07b77-6bdf-11eb-87cd-6805ca007b16, can't open
Mar 11 20:50:05 freenas vdev.c:183:vdev_dbgmsg_print_tree(): vdev 3: disk, guid: 5188781440804839517, path: /dev/gptid/a5ddfe79-6bdf-11eb-87cd-6805ca007b16, can't open
Mar 11 20:50:05 freenas spa_misc.c:411:spa_load_note(): spa_load($import, config untrusted): UNLOADING
Mar 11 20:50:05 freenas spa.c:5990:spa_import(): spa_import: importing Pool-02
Mar 11 20:50:05 freenas spa_misc.c:411:spa_load_note(): spa_load(Pool-02, config trusted): LOADING
Mar 11 20:50:05 freenas Pools import completed
Mar 11 20:50:05 freenas Loading kernel modules:
Mar 11 20:50:05 freenas Setting hostname: freenas.local.
Mar 11 20:50:05 freenas Setting up harvesting: PURE_RDRAND,[UMA],[FS_ATIME],SWI,INTERRUPT,NET_NG,NET_ETHER,NET_TUN,MOUSE,KEYBOARD,ATTACH,CACHED
Mar 11 20:50:05 freenas Feeding entropy: .
Mar 11 20:50:05 freenas Starting interfaces...
Mar 11 20:50:05 freenas Generating configuration for interface_sync checkpoint
Mar 11 20:50:05 freenas ELF ldconfig path: /lib /usr/lib /usr/lib/compat /usr/local/lib /usr/local/lib/compat/pkg /usr/local/lib/compat/pkg /usr/local/lib/e2fsprogs /usr/local/lib/gcc7 /usr/local/lib/gcc9 /usr/local/lib/perl5/5.30/mach/CORE /usr/local/lib/samba4
Mar 11 20:50:05 freenas 32-bit compatibility ldconfig path:
i can't undestand that.. 2 disk fails at same time ?... thay are 1 month old...
i really don't understand.. Pool-1 are 4 seagate with more than 10 years... really is that the error?
it can be fixed ?
