mcantkier
- Mar 9, 2021
Obligatory server information:
Supermicro X11SCA-F Version 1.01A
Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
64GB ECC DDR4 (16GB DIMM's)
8 x 10TB Ironwolf (2 RAIDZ1 VDEV's) [ST10000VN0008-2J]
2 x CT480BX500SSD1 SSD's (Mirrored) Boot
LSI SAS2308 HBA IT Mode
Intel 10GB 2 x SFP+
Onboard 1GB
TrueNAS-12-0-U2
Trying to import an old pool on a fresh install. The import runs for several hours then the system hangs. This is the only console output I have:
Any ideas?
Before I ran the import from the gui I ran this on the pool:
zdb -e -bcsvL VeeamPool
Intel 10GB 2 x SFP+
Onboard 1GB
TrueNAS-12-0-U2
Any ideas?
Traversing all blocks to verify checksums ... 34.5T completed ( 65MB/s) estimated time remaining: 296473hr 13min 06sec bp count: 1747919408 ganged count: 0 bp logical: 28763745054208 avg: 16455 bp physical: 24702574020608 avg: 14132 compression: 1.16 bp allocated: 37886862581760 avg: 21675 compression: 0.76 bp deduped: 0 ref>1: 0 deduplication: 1.00 Normal class: 37869691486208 used: 47.51% additional, non-pointer bps of type 0: 4919925 Dittoed blocks on same vdev: 2137675 Blocks LSIZE PSIZE ASIZE avg comp %Total Type - - - - - - - unallocated 2 32K 8K 48K 24K 4.00 0.00 object directory 6 3K 2K 96K 16K 1.50 0.00 object array 1 16K 4K 24K 24K 4.00 0.00 packed nvlist - - - - - - - packed nvlist size 10 1.25M 40K 240K 24K 32.00 0.00 bpobj - - - - - - - bpobj header - - - - - - - SPA space map header 45.9K 561M 425M 2.02G 45.2K 1.32 0.01 SPA space map 34.3K 4.29G 4.29G 5.90G 176K 1.00 0.02 ZIL intent log 6.74K 125M 27.3M 111M 16.4K 4.57 0.00 DMU dnode 29 106K 106K 472K 16.3K 1.00 0.00 DMU objset - - - - - - - DSL directory 26 13K 1.50K 72K 2.77K 8.67 0.00 DSL directory child map 24 12K 512 24K 1K 24.00 0.00 DSL dataset snap map 36 328K 56K 480K 13.3K 5.86 0.00 DSL props - - - - - - - DSL dataset - - - - - - - ZFS znode - - - - - - - ZFS V0 ACL 237K 9.77G 7.17G 10.6G 45.9K 1.36 0.03 ZFS plain file 18.2K 21.4M 11.4M 121M 6.64K 1.89 0.00 ZFS directory 22 22K 18K 352K 16K 1.22 0.00 ZFS master node - - - - - - - ZFS delete queue 1.63G 26.1T 22.5T 34.4T 21.2K 1.16 99.95 zvol object - - - - - - - zvol prop - - - - - - - other uint8[] - - - - - - - other uint64[] - - - - - - - other ZAP - - - - - - - persistent error log 1 128K 12K 48K 48K 10.67 0.00 SPA history - - - - - - - SPA history offsets - - - - - - - Pool properties - - - - - - - DSL permissions - - - - - - - ZFS ACL - - - - - - - ZFS SYSACL - - - - - - - FUID table - - - - - - - FUID table size 1 1.50K 1.50K 24K 24K 1.00 0.00 DSL dataset next clones 1 1K 1K 24K 24K 1.00 0.00 scan work queue 77 44.5K 9K 96K 1.25K 4.94 0.00 ZFS user/group/project used - - - - - - - ZFS user/group/project quota - - - - - - - snapshot refcount tags - - - - - - - DDT ZAP algorithm - - - - - - - DDT statistics - - - - - - - System attributes - - - - - - - SA master node 23 34.5K 32.5K 368K 16K 1.06 0.00 SA attr registration 44 704K 144K 704K 16K 4.89 0.00 SA attr layouts - - - - - - - scan translations - - - - - - - deduplicated block - - - - - - - DSL deadlist map - - - - - - - DSL deadlist map hdr 1 1.50K 1.50K 24K 24K 1.00 0.00 DSL dir clones - - - - - - - bpobj subobj - - - - - - - deferred free - - - - - - - dedup ditto 43 330K 29.5K 240K 5.58K 11.17 0.00 other 1.63G 26.2T 22.5T 34.5T 21.2K 1.16 100.00 Total Block Size Histogram block psize lsize asize size Count Size Cum. Count Size Cum. Count Size Cum. 512: 22.5K 11.2M 11.2M 22.4K 11.2M 11.2M 0 0 0 1K: 25.9K 32.0M 43.2M 25.8K 31.8M 43.1M 0 0 0 2K: 41.4K 110M 153M 41.4K 110M 153M 0 0 0 4K: 144M 576G 576G 73.9K 340M 493M 0 0 0 8K: 303M 2.91T 3.47T 21.3K 235M 728M 144M 1.12T 1.12T 16K: 1.19G 19.0T 22.5T 1.62G 25.9T 25.9T 1.48G 33.1T 34.2T 32K: 10.0K 469M 22.5T 6.75M 216G 26.1T 6.64M 213G 34.4T 64K: 8.54K 711M 22.5T 3.36K 297M 26.1T 11.8K 1005M 34.4T 128K: 77.4K 9.68G 22.5T 103K 12.9G 26.1T 78.4K 13.4G 34.5T 256K: 0 0 22.5T 0 0 26.1T 2.55K 1005M 34.5T 512K: 0 0 22.5T 0 0 26.1T 0 0 34.5T 1M: 0 0 22.5T 0 0 26.1T 0 0 34.5T 2M: 0 0 22.5T 0 0 26.1T 0 0 34.5T 4M: 0 0 22.5T 0 0 26.1T 0 0 34.5T 8M: 0 0 22.5T 0 0 26.1T 0 0 34.5T 16M: 0 0 22.5T 0 0 26.1T 0 0 34.5T capacity operations bandwidth ---- errors ---- description used avail read write read write read write cksum VeeamPool 34.4T 38.1T 12.3K 0 113M 0 0 0 0 raidz1 17.2T 19.0T 6.16K 0 56.4M 0 0 0 0 /dev/gptid/5fcda43c-a1c4-11ea-a88f-40a6b70bd3f8 1.58K 0 14.4M 0 0 0 0 /dev/gptid/5f6bb273-a1c4-11ea-a88f-40a6b70bd3f8 1.50K 0 13.8M 0 0 0 0 /dev/gptid/601426e7-a1c4-11ea-a88f-40a6b70bd3f8 1.58K 0 14.4M 0 0 0 0 /dev/gptid/603659fe-a1c4-11ea-a88f-40a6b70bd3f8 1.50K 0 13.8M 0 0 0 0 raidz1 17.2T 19.0T 6.15K 0 56.3M 0 0 0 0 /dev/gptid/5e2dcba9-a1c4-11ea-a88f-40a6b70bd3f8 1.58K 0 14.3M 0 0 0 0 /dev/gptid/5ea72078-a1c4-11ea-a88f-40a6b70bd3f8 1.50K 0 13.8M 0 0 0 0 /dev/gptid/5ff12b3d-a1c4-11ea-a88f-40a6b70bd3f8 1.58K 0 14.3M 0 0 0 0 /dev/gptid/5f95e5cf-a1c4-11ea-a88f-40a6b70bd3f8 1.50K 0 13.8M 0 0 0 0
