The docs for truenas core's minio plugin specifies several times that the user should mount a data set for the underlying object store, but never specified WHERE to mount that dataset: https://www.truenas.com/docs/core/13.0/coretutorials/jailspluginsvms/plugins/minioplugin/, nor is there a picture showing where the dataset might be mounted.
That being said, where do I mount my dataset so that the raw object / bucket storage is saved. Ideally the chosen path will behave identically to how the S3 service acted and the dataset contains the raw files/dirs identical to the objects/buckets.
